HELP! 2007 Dodge 2500 4low works, but no 4hi
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #11
It sounds like the shift solenoid is out of whack or the shift fork.
Chris
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #12
that's one thig I was thinking.. solenoid.. it's what was sticking on my gmc..
soundguy
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #13
I'm thinking solenoid too. Good luck!
try driving backwards, then forewards and then shift to N and then try to engage it.
had to do that once onmy yukon that has the shifter button on the dash.. hadn't used 4wd in a while and it got sticky.
I like my dodge 1500 with shifter on the floor.. no doubts about when / if it shifts :)
soundguy
I have tried it everyway possible. I hear the xfer case making the noise like it does when it shifts but still nothing. I don't know if that is good or bad. :confused:
I guess next I will change the fluid (needs doing anyway) and check for metal.
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #15
If your truck is a 2007.5, is it still under coverd under the bumber to bumber policy????:confused:
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #16
It would actually be the powertrain warranty. He said he was out of warranty so I am guessing he has lots of miles.
Chris
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #18
my 07 Dakota has a lifetime power train warranty he might want to check on that!! Not sure on the "real" trucks! :D
Chris
My truck has 78,000 miles. The person I talked to at the local dealer said that all I left under warranty was the engine itself. :(
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #20
I would look into that. I though that era of Dodge had 10/100,000 mile powertrain warranty.
My 03 had a 6/60,000 mile I think and I got a tranny replace at nearly 40,000 miles.
Where is Dmace when we need him?
Chris
LOT: (48) 2.5 Gallons of Star Fire Diesel Exhaust Fluid (A59076)
LOT: (48) 2.5...
Kubota R5205 (A57148)
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
