80% Clay Loom?!? Which Bucket?
   / 80% Clay Loom?!? Which Bucket? #1
Lockport
Lockport, Manitoba
Bobcat CT235
Here's a bucket question: Where I am, our muck is thick and heavy. 80% clay. Can a 7' hoe with 2800lbs breakout at the bucket and 2,000lbs on the dipperstick be able to dig to its capacity with a 16" bucket?
   / 80% Clay Loom?!? Which Bucket? #2
The only sure way to due this with a wide bucket
like yours and the heavy clay is to peel the dirt
away in layers as the bucket has a huge surface
area which increases the amount of resistance.
In any case with a small back hoe for any job it is
better to peel small layers of dirt away as you work
as the cylinders do not have stop tubes and the
upper boom, lower boom and dipper cylinders do
not have relief valves mounted on the cylinders
in most cases.
If you had a narrow trenching bucket you would be
better off as it will offer less resistance and create
less stress on the cylinders and lower boom.
   / 80% Clay Loom?!? Which Bucket? #3
A narrow trenching bucket will pack full of any type of dirt, other than shale. In other words, they are one of those good ideas that isn't. Good sharp bucket teeth are the answer.
   / 80% Clay Loom?!? Which Bucket? #4
look at the backhoe bucket closely, mine has a power dig setting, and also a truck loading setting.
   / 80% Clay Loom?!? Which Bucket? #5
I am able to fill my 12" bucket full with wet red clay....the problem is emptying the full bucket, the wet clay is sooooo sticky it doesn't empty very well.:confused:
   / 80% Clay Loom?!? Which Bucket? #6
An "Ejecto" bucket option would be worth
its wieght in gold wih sticky material but
you would lose about a half of its actual
volume and you would need one more spool
or an accumulator to store fluid energy on a
continuos basis with fluid flow using a regulating
valve to open and close the pusher plate
automatically with a level bucket.
:drool::thumbsup:
   / 80% Clay Loom?!? Which Bucket? #7
:drool::thumbsup:
:drool::laughing:
I don't suppose there is some kind of teflon spray you could buy?
Nuts,there goes another million $$$ idea out the window,:D:D:D
ATTENTION! PLEASE READ (A53316)
ATTENTION! PLEASE...
2025 Swict 60in Bucket Skid Steer Attachment (A55787)
2025 Swict 60in...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
1969 REO M35 2.5 Ton Military Truck 6x6 (A55788)
1969 REO M35 2.5...
New Mahindra 2665CL Loader (A50775)
New Mahindra...
Henderson Stainless Steel Salt Spreader (A50775)
Henderson...
