031av muffler repair, use JBWeld??
   / 031av muffler repair, use JBWeld?? #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
The side flange (support piece) on my 031av muffler has come loose... Do you think JB weld would/could be used to repair it?
I took a quick look at ebay a new muffler was $70, used ones were $20ish, but most seemed to have 'issues' .. I am heading to a dealer to see their cost, but for no more than it gets used I cant see putting $70 in a almost 40 yr old saw..
If not JB Weld, any other suggestions?
Brian
   / 031av muffler repair, use JBWeld?? #2
I doubt that JB would take the heat. May have to silver solder it.
   / 031av muffler repair, use JBWeld?? #3
Is it unusable as it is? Other than being louder, is there a problem?
   / 031av muffler repair, use JBWeld?? #4
The muffler will get hot enough to burn the JB Weld and you will have a real mess. I had an 031 AV up until 2 years ago. It was a good reliable saw but it vibrated much more than the newer saws due. The 031's still seem to be a hot seller on ebay in the $150 range.
There is a good used muffler on ebay right now for your saw for $19.99 buy it now.
The auction item # is: 140530606039
It appears to be usable as is.. not sure if the gasses coming out of the side of the muffler toward the bar would be ideal though..
Looking online i found some Permatex puddys and such for exhaust repairs.. Anyone try those?
Brian
   / 031av muffler repair, use JBWeld?? #6
Bronze it? If its possible, it would be the only method id trust
I am assuming, since i have no idea how to 'bronze' is - that its not a DIY job.. LOL
Brian
   / 031av muffler repair, use JBWeld?? #8
Could you post a pic of damage.
I had a 031 with the module going out it. Run 30mins heat up, break up, shut down. Wait to cool to do it again. The part that was going bad was NLA.
I noticed back then the 031 had 2 different muffler types.
   / 031av muffler repair, use JBWeld?? #9
Brian
:thumbsup: Sorry. Bronze = Braze ("solder") using acetylene touch with bronze filler rod. Would definitely be DIY assuming you had a torch... Good excuse to go buy one :D
the muffler on the saw has a different looking exhaust hole than the ones I see on ebay.. This saw does NOT have a chain brake, so it is an earlier model than most you see..
My neighbor is a certified welder and he thought he could fix it for me, so i just dropped it off at his house this morning.. It was a stress crack/fracture - when i took it apart one of the header bolts was missing and the other was loose - so i think the shaking cracked the piece..
I can't find a pic of it except on ebay.. But the flange that broke has a bolt that goes thru/near that chain oiler into the muffler..
The muffler is no longer available (no surprise there) - BUT the dealer list price would be $170 if they had one in stock... $70 for new or $30 for used on ebay sounds better and better if the welding doesnt help..
Brian
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
