031av muffler repair, use JBWeld??
   / 031av muffler repair, use JBWeld?? #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
The side flange (support piece) on my 031av muffler has come loose... Do you think JB weld would/could be used to repair it?
I took a quick look at ebay a new muffler was $70, used ones were $20ish, but most seemed to have 'issues' .. I am heading to a dealer to see their cost, but for no more than it gets used I cant see putting $70 in a almost 40 yr old saw..
If not JB Weld, any other suggestions?
Brian
   / 031av muffler repair, use JBWeld?? #2
I doubt that JB would take the heat. May have to silver solder it.
   / 031av muffler repair, use JBWeld?? #3
Is it unusable as it is? Other than being louder, is there a problem?
   / 031av muffler repair, use JBWeld?? #4
The muffler will get hot enough to burn the JB Weld and you will have a real mess. I had an 031 AV up until 2 years ago. It was a good reliable saw but it vibrated much more than the newer saws due. The 031's still seem to be a hot seller on ebay in the $150 range.
There is a good used muffler on ebay right now for your saw for $19.99 buy it now.
The auction item # is: 140530606039
It appears to be usable as is.. not sure if the gasses coming out of the side of the muffler toward the bar would be ideal though..
Looking online i found some Permatex puddys and such for exhaust repairs.. Anyone try those?
Brian
   / 031av muffler repair, use JBWeld?? #6
Bronze it? If its possible, it would be the only method id trust
I am assuming, since i have no idea how to 'bronze' is - that its not a DIY job.. LOL
Brian
   / 031av muffler repair, use JBWeld?? #8
Could you post a pic of damage.
I had a 031 with the module going out it. Run 30mins heat up, break up, shut down. Wait to cool to do it again. The part that was going bad was NLA.
I noticed back then the 031 had 2 different muffler types.
   / 031av muffler repair, use JBWeld?? #9
Brian
:thumbsup: Sorry. Bronze = Braze ("solder") using acetylene touch with bronze filler rod. Would definitely be DIY assuming you had a torch... Good excuse to go buy one :D
the muffler on the saw has a different looking exhaust hole than the ones I see on ebay.. This saw does NOT have a chain brake, so it is an earlier model than most you see..
My neighbor is a certified welder and he thought he could fix it for me, so i just dropped it off at his house this morning.. It was a stress crack/fracture - when i took it apart one of the header bolts was missing and the other was loose - so i think the shaking cracked the piece..
I can't find a pic of it except on ebay.. But the flange that broke has a bolt that goes thru/near that chain oiler into the muffler..
The muffler is no longer available (no surprise there) - BUT the dealer list price would be $170 if they had one in stock... $70 for new or $30 for used on ebay sounds better and better if the welding doesnt help..
Brian
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2021 KENWORTH T680 SLEEPER (A51222)
2021 KENWORTH T680...
