Tire and Wheel Size, Bolt Pattern, Different Tractors
   / Tire and Wheel Size, Bolt Pattern, Different Tractors #11
Try this, take the part numbers of your rims go to the parts catalog screen on jd parts click on"Where Used" tab and enter the part number and see if anything comes up. You may have tried this already but this is the only thing that comes to mind
Great idea!!!That worked. It told me I'm &%$*@#? The rear wheels only fit a new 3038e,3032e amd a 3036E. Front wheels fit all 3000 series tractors
   / Tire and Wheel Size, Bolt Pattern, Different Tractors #14
Great idea!!! tHAT WORKED. iT TOLD ME i AM &%$*@#? The rear wheels only fit a new 3038e,3032e amd a 3036E. Front wheels fit all 3000 series tractors
Is it possible that your wheel will also fit other tractors, but that part numbers are different because of slightly differing offsets, rim widths, rim designs, hub designs, valve placements, paint colors, etc. I mean they should fit anything with the right bolt pattern and center size that's close to the right offset, yes?
xtn
   / Tire and Wheel Size, Bolt Pattern, Different Tractors #15
xtn
Should, but you also have to determine if the tire/rim assembly will fit the tractor.
If the PN's are different, but the center hole and bolt circle are the same, the only way a potential buyer will know if the tires/rims will work is by a trial fit up.
8ft. Teakwood Dining Room Table (A56859)
8ft. Teakwood...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
48ft all aluminum feather light wedge trailer (A56436)
48ft all aluminum...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
Pallet of Assorted Hand Tools (A57454)
Pallet of Assorted...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
