Hydraulic Skidding Winch Project
   / Hydraulic Skidding Winch Project #21
I still have to find out realistically what pulling force I could get with 14.5HP.
It is not just the HP, but how you reduce the speed. If you 1/2 the speed, the torque will double. If you reduce the speed 6 times, the torque will be times 6 greater. That torque will be on the drum. Then the diameter of the drum has to be considered, and which layer you are pulling from.
I have no idea how to figure the pulling force, say in pounds.
The gear ratio is 29:1, the drum diameter is 4.25" or circumference is 12.95" and it's 10" wide for the first layer.
1 HP = 550 ft lb/s
14.5 HP = 7,975 ft lb/s
So, 14.5 HP(7,975 FT LB/S)
29:1 Gear Ratio
12.95" Drum Circumference
From there I don't know howto find the ft lb/s of pulling force. I'm trying to find an equation to use with Google Search but I have not found it yet.
How do I get a moderator move this to "Build It Yourself"?
As I am not going to use Hydraulics anymore.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
