Any Good Uses for Busted Leaf Springs?
   / Any Good Uses for Busted Leaf Springs? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
In the process of re-building a trailer I found a busted leaf spring. Right now the leaf spring is in the scrap bin, but I wondered if there is some genius use for it worth more than the 4 cents a pound or whatever I'd get at the scrap yard.
Any and all suggestions welcome.
   / Any Good Uses for Busted Leaf Springs? #2
I made a homemade 3pt fork, using 2 equal length leafs as forks.
   / Any Good Uses for Busted Leaf Springs? #3
I have one about 2 inches wide from back when springs were tapered thin toward the end and the end was rounded. My father used it as a tire iron on his A-Model ford tires so I continued the tradition. Just a few years ago I bought one similar at a garage sale that is just a little shorter and about 1-1/2 inches wide. They make a perfect pair. They are half of a full length springs.
   / Any Good Uses for Busted Leaf Springs? #4
We use to sharpen them and peel pulpwood - good for peeling fence rails.
   / Any Good Uses for Busted Leaf Springs? #5
Leaf spring material is a hard steel. I can be used to make all kinds of tools and such. If it were me, I'd keep every piece of it.
No Kidding!!! I guess I thought the springs would flex too much. Those must have come from some very big springs.
   / Any Good Uses for Busted Leaf Springs? #8
No, the springs are actually medium size, maybe from a 1/2 ton pickup. They do flex some, but it hasn't been a problem so far.
   / Any Good Uses for Busted Leaf Springs? #9
Single spring works great as drywall (or any sheet material) lifter. Stand wall board up and slip arced spring under apply foot pressure and presto!!
   / Any Good Uses for Busted Leaf Springs? #10
In third world countries where they recycle everything I have seen them used for cutting edges, for heal plates on buckets, harrow teeth and a hundred other things I can't remember right now.
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2003 Big Tex 10PI...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
