kubota bx2200 wont start
   / kubota bx2200 wont start #1
gerry w
kubota bx2200
battery is good, turn key on i can hear fuel pump but nothimg happens.
   / kubota bx2200 wont start #2
Welcome to TBN. :)
   / kubota bx2200 wont start #3
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Kubota Owning/Operating Forum. You'll get a better response there. ;)
   / kubota bx2200 wont start #4
:welcome:
Checked the fuses? The starter make any clicking? The switch may be bad.
   / kubota bx2200 wont start #5
check battery cables at both ends also as well as all safety switches.:)
   / kubota bx2200 wont start #7
On my BX, it seems like it is the PTO lever, I just jiggle it a little, and it usually starts.
   / kubota bx2200 wont start #8
Same here, and I adjusted my switch recently, and that went away for me. I never have had a problem with the rabbit/turtle lever on my BX; only the PTO needed the jiggle, but not any longer.
My BX2200 does not have a seat switch..but some of the BX's do have that.
   / kubota bx2200 wont start #9
I'd check (in this order):
1. In neutral
2. PTO disengaged
3. Safety Switches
4. Fuses
5. Battery Connections
6. Battery Voltage
7. Solenoids
8. Wiring Harness
I have had every one of these problems prevent my BX2200 from starting at some point or other.
   / kubota bx2200 wont start #10
How would I go about bypassing the safty switches to see if they are the problem?
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
43013 (A51691)
43013 (A51691)
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
Tesco 200 Gallon Tank (A50774)
Tesco 200 Gallon...
