Plugged grease joint
   / Plugged grease joint #11
when I got my tractor about half of the zerks wouldn't take grease. I took the entire pins out and wire brushed them and then sprayed the zerks with purple stuff and worked the little ball with a small pointed pick. When I put them back all but one of them worked like new, so I replaced that one. It took be a couple of easy evenings after work to clean them up. Now that I grease it more than the original owner, they are working fine.
   / Plugged grease joint #12
You are correct. However, having a bunch of different equipment, some metric some SAE and always finding some zerk that you don't have a replacement for is a pain. But, your approach makes a lot of sense too.
That makes sense. I can see where that would be $40 well spent, just to save time.
Not on mine. I had already replaced the zerks. The hole from the zerk goes to about the middle of the pin then out to the side where there is a distribution grove cut in the pin. That hole was packed hard with dirt. The zerks were not the problem at all.
But isn't the dirt coming through the zerk? A capped zerk would stop that from happening. I think.
   / Plugged grease joint #13
Just had to replace 10 zerks on a 3pt disc I bought. The heat trick worked on 3 of them. Just hold a small solder torch up to it, and it was clean. most of the others were broken off. I figure they were all cross threaded. I thought of the hammer cleaner they sell at TSC, but like the other guy said you can buy a lot of fittings for $40.
   / Plugged grease joint #14
A zerk has a spring-loaded ball that seals it. As long as you wipe the dirt away from the top of zerk before you grease it, all is good.
In my case the dirt came in around the pivot pin simply because there was no grease. Finally it got packed into the grease channel. I had to replace 2 rod-bucket links because they were worn from not being greased.
   / Plugged grease joint #15
I can't grease into one of the zerks on my FEL, I was planning on getting one of those tools that blow the joint open by forcing oil into it...those things you hit with a hammer. Does the Harbor Freight cheapie work? The better ones are over twice as expensive....I'll spend it if I have too, but would prefer to go the cheap route for the limited use I'll have for it.
The Harbor Freight unit worked for me. I had two zerks that I was having trouble with. I used the HF unit loaded with transmission fluid. Only took about two whacks with the hammer on the first one and everything cleaed up and I could grease it then.
The second zerk was not so friendly. I could not get it to take anything. I took the zerk off, and it would let grease go though it so I figured it was not the zerk. I had to dig dried grease out with a piece of wire, especially in the channel on the part. I replaced with a new zerk after cleaning and all was well.
The HF tool would be my first "go to" solution. It was much easier than digging out the old grease.
   / Plugged grease joint #17
I've found that in most cases, it's the grease in bearing that has become hard that stops new grease from coming in. I take out the zirk fitting and clean out what I can get in the hole and then spray break cleaner in there to break down and clean out the remaining grease. I put the zirk back in and pump in new grease.
Eddie
   / Plugged grease joint #18
Might not do this on the tractor but I had 2 stopped up ones on my disc that I couldnt get free with heat.. Took the pressure washer one day cleaning and shinning and buffing the disc.:) and hit both zerks with it and bang no more stopped up... I then pumped grease into them and flushed all the water out.. Worked great and that was last fall...
AndyG
   / Plugged grease joint #19
Just curious.. I have a couple zerks that I can get a pump or two into.. Then the grease starts coming back out of the middle of the zerk..
Is that a stopped up zerk OR just doesnt need grease?
thanks
b
   / Plugged grease joint #20
If the zerk is stuck with dirt, using that impact tool just drives the dirt into you pivot (the area you are trying to keep clean & lubricated). Personally I would not use one. I have friends at equipment dealers that sell them but do not use them in their shops and not on their presonal equipment.
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
Makinex Electric Powered Hand Truck (A52377)
Makinex Electric...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
