oil question
   / oil question #1
liajane
in regards to chainsaws what is "bar oil"?which part does it lubricate?thank
liajane
   / oil question #4
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Oil fuel & Lubricants Forum. You'll get a better response there. ;)
   / oil question #5
It is a must use It helps the chain slide in the grove and keeps the chain flexiable. and welcom to TBN.
   / oil question #6
I will second what others said. It keeps teh chain flexible and from rusting and allows the lubrication of the drive links of chain, the sprocket on the saw and the bar and grove the cahin rides in to reduce wear and heat. It contains additives to make it tacky so it dosent sling off at the high speeds. Some buy "bar oil" labeled as such and im sure if we talk about this long enough you will get those that say you dont need "bar oil" just any oil new or used will do. This i will leave up to you, i personally would use new "bar oil" labeled as such, it costs around $10/gallon and unless you cut 10 cords of firewood a year a gallon will probly last your 2 years if not more. I cut firewood for heating my home partially and one gallon will last me about 18 months or so. I will leave the decision up to u like i said, i gues it boils down to your knowlege of repairs ability, how refined/new your saw is, is it under warrenty and or what your "dad did".
   / oil question #7
but, daddy said, daddy said, my daddy said that dem aligators wuz onrey cause dey aint got no toof brush!!.. you're WRONG kernel sanders!!...
hahaha... sorry guys, been taking some cough syrup the last couple of days...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
1995 Western Star 4900 T/A Wrecker Tow Truck (A53422)
1995 Western Star...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
