What is a 'remote valve' and why do I want one?
   / What is a 'remote valve' and why do I want one? #1
LMan1967
Gold Member
Kudzu, Alabama
MF 1643
...and yes, I have "The Book" and its not in there :(
   / What is a 'remote valve' and why do I want one? #2
Its a valve in the back of your tractor. It allows you to attach equipment that requires hydraulics. Depending on what your doing you may never need one.
   / What is a 'remote valve' and why do I want one? #3
I use mine for a hydraulic top link, pull type rotary cutter and have used them for log splitter also handy if you want a hydraulic back blade or box blade with with hydraulic scarifiers.
   / What is a 'remote valve' and why do I want one? #4
usually unless you are in the compact size tractor, most of the tractors come with one standard
   / What is a 'remote valve' and why do I want one? #5
loader valves are technically remote valves as well. You can also get mid mount and loader mount valves for various equipment.
Examples of remote hydraulic equipment: side boom mowers, bat-wing mowers, grapples, top-n-tilt kits, and the list goes on.
Not always necessary but can be real handy. Get the remotes if you can.
   / What is a 'remote valve' and why do I want one? #6
For loader enhancements like a grapple, you will also see them referred to as 'third function' remotes or valves sometimes.
As in: function 1 is raising the loader arms, function 2 is curling/dumping the bucket and the 3rd function would be closing/opening the grapple arms.
Dave.
   / What is a 'remote valve' and why do I want one? #7
Dave.
yup but many people run their mid or rear remotes up to the bucket to use as 3rd function. Just giving examples of extra hydraulic functions...
   / What is a 'remote valve' and why do I want one? #8
Oh, I wasn't disagreeing with you at all, just carrying on with what you said to mention it may be the same thing with a different name, and what the third function name means - more or less :)
Dave.
   / What is a 'remote valve' and why do I want one? #9
ah nope. While looking at 40-50 HP tractors, i found that JD and Kubots offered them as extras ONLY. not sure why....all tractors SHOULD come with at least 1 rear remote, but they dont. and its a $900 - 1250 extra to add. Their LARGE farm tractors all had them as standard though
   / What is a 'remote valve' and why do I want one? #10
You don't want one............. you want TWO. At a minimum.
36'' Mini Excavator Bucket (A51573)
36'' Mini...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
New/Unused CFG Industrial NT18K Mini Excavator (A51573)
New/Unused CFG...
43029 (A51691)
43029 (A51691)
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
