Tow behind wood chipper
   / Tow behind wood chipper #1
timberwolves
Delaware County, N.Y. & Seaford, L.I.
Massey Ferguson MF-65
I have a Morbark Eeger Beever model 200 tow behind wood chipper. I need to adjust the knives on this unit. I was told the tolerances were 50 - 100 thousands of an inch from the highest blade. Does anyone know how to make these adjustments ? I have installed new blades already and when I use the chipper the wood chips are big. It is my understanding that adjusting them it will make the wood chips smaller. Thank you John
   / Tow behind wood chipper #2
If I'm correct the Eager Beaver is a flywheel chipper not a drum. Typically this adjustment is made with the "bed blade". It might not look like a blade but a plate that adjusts in and out from the flywheel. A wider gap will result in larger chips and takes more power but chips faster. A closer gap will produce smaller chips and take less power but chips slower. Which engine does yours have? I think they had a 80hp gasoline and a 76hp cummins diesel. The cummins might have a little more torque.
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
SITREX HAY TEDDER (A54756)
SITREX HAY TEDDER...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
ASCO Transfer Switch (A52377)
ASCO Transfer...
