LT 16 starting problem
   / LT 16 starting problem #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I thought I had a dead battery. I tried to jump it with battery hooked up and without only get a clicking sound ???
   / LT 16 starting problem #2
Check your safety switches. PTO,brake,seat etc.
   / LT 16 starting problem #4
On my trim mower the seat switch trans neutral and PTO have indicator lights that will tell you they are working. I can't tell you how many times someone has my "....." won't start and the trannie is not in neutral PTO not off parking brake not set etc.
thanks for the reply. Dropped it off at the shop yesterday. Should know something by the 22nd of the month.
   / LT 16 starting problem #6
It's not a safety switch. You won't get anything with a switch open.
The 'click' is likely the starter solenoid, so I'd guess that the starter itself is dead. It could be as simple as a loose wire.
JayC
Edit: Oops - I see that you went the shop route - so, what was the verdict?
   / LT 16 starting problem #7
Actually with one of my switches PTO I think, I get a definite click when turning to start.
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
40ft Sea Container (A52384)
40ft Sea Container...
