LT 16 starting problem
   / LT 16 starting problem #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I thought I had a dead battery. I tried to jump it with battery hooked up and without only get a clicking sound ???
   / LT 16 starting problem #2
Check your safety switches. PTO,brake,seat etc.
   / LT 16 starting problem #4
On my trim mower the seat switch trans neutral and PTO have indicator lights that will tell you they are working. I can't tell you how many times someone has my "....." won't start and the trannie is not in neutral PTO not off parking brake not set etc.
thanks for the reply. Dropped it off at the shop yesterday. Should know something by the 22nd of the month.
   / LT 16 starting problem #6
It's not a safety switch. You won't get anything with a switch open.
The 'click' is likely the starter solenoid, so I'd guess that the starter itself is dead. It could be as simple as a loose wire.
JayC
Edit: Oops - I see that you went the shop route - so, what was the verdict?
   / LT 16 starting problem #7
Actually with one of my switches PTO I think, I get a definite click when turning to start.
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
UNUSED LANDHONOR LHR-AIW1-1" AIR IMPACT WRENCH (A54757)
UNUSED LANDHONOR...
Ford F450 Bucket Truck with Altec AT200A Boom (A55218)
Ford F450 Bucket...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
