transporting ford 8n from wyoming to oregon
   / transporting ford 8n from wyoming to oregon #11
need some awesome ramps to do that. or a good ditch to back into and good ramps..
soundguy
   / transporting ford 8n from wyoming to oregon #12
soundguy
Or an embankment, loading dock and/or rollback truck to back up to at either end.
   / transporting ford 8n from wyoming to oregon #13
I purchased a ford 8n but it is in wyoming and I live in bend oregon I just wanted a old tractor to play with but now I find the shipping costs are way high Twice what I paid for tractor I don't know what to do can it be moved on a car trailer any suggestions would be appreciated. Thanks John
Go to Uship.com, follow the instructions (they're easy) to list your load and input the weight (probably 2500-3000 lb for your 8N), type of load (agriculture vehicle or similar) and start and destination zip codes. You'll get a list of recent jobs closely similar to yours with the freight costs. Then make your decision.
   / transporting ford 8n from wyoming to oregon #14
If this is just a bare 8N I agree...The one I had posessed had a front loader, filled tires and various impliments...I hauled that to the new house and it was probably as heavy as my 32' ft travel trailer. Can't quantify, just "pull feel".
   / transporting ford 8n from wyoming to oregon #15
What type of tow vehicle and trailer do you have? The 8n is fairly lite tractor at about 3k lbs so a 1/2 ton can do it easily.
no need for a truck to pull 3000 pounds, i pull 4k tractors behind my Volvo. Just make sure your brakes are working, and that you have the correct tongue weight, about 5% of the load. With my 3011 on the trailer, (weighing just a bit more than an 8N) its an easy ride.
   / transporting ford 8n from wyoming to oregon #16
it's not just the tractor weight.. it's also the trailer. typical trailer is a 16' tandem.. at about 2000#
making that a 5k# load.. meaning class III hitch or better.
most 'cars' here have a class I or II hitch only.
soundguy
   / transporting ford 8n from wyoming to oregon #17
soundguy
My 2.5 ton, 6 by 12 foot tandem weighs 430kg, on the papers. I guess it depends on whats commonly available.
   / transporting ford 8n from wyoming to oregon #18
over here, a 7' x 16' tandem wood deck 'car hauler' is a more or less standard for the people with tractors of 35hp and lower. mine papers out to 1740# WITHOUT ramps. and I have a set of 3 heavy ramps for it that weasilyl wight 100-120# each.
soundguy
   / transporting ford 8n from wyoming to oregon #19
Hmm i'm wrong... the legal load capacity is 1930kg, which means 570kg empty weight...
You can buy a 430kg 2 ton trailer, but those are disposable junk, made of 2mm pressed steel... Mine has a truss frame.
In Europe the 2 ton tandem deck-over, is the most popular light commercial trailer. extending trailer length, quickly adds weight because a longer bed needs stronger frame members too... Though i sometimes wish i had more length to balance out the load better, a shorter trailer takes less storage room, and i'm not dragging dead weight along when just getting a few 2 by 4's...
What i want to do this winter, is put it on smaller 13" tires and drop the deck 6 inches, so i can use shorter ramps, and it has less wind resistance with a tractor on it. It makes a noticable difference in fuel consumption.
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58216)
2023 WRANGLER...
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
2006 Godwin GHP45KW-RC45kW Towable Generator (A56857)
2006 Godwin...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Giyi Breaker Hammer (A57149)
Giyi Breaker...
