Shaver post driver
   / Shaver post driver #1
Walter63
I have a Shaver HD8 with hydraulic positioning. In operation, the force of the impact can cause the vertical positioning cylinder ram to move 3/4" or so. In other words, under sudden force, the cylinder isn't holding rigidly. I can't see how there would be any air in the system that would cause this, so the only other possibility is a leak in the cylinder or valve. That seems unlikely as the unit only has a few hours on it. Any ideas, or anyone had this experience?
A related question regards hydraulic restrictors. The positioning cylinders move way too fast to be of use, so I want to insert a simple orifice restrictor to slow the flow in both directions on the positioning cylinders. Can anyone recommend a source for a simple non-adjustable restrictor?
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
Charlotte County (A50323)
Charlotte County...
UNUSED 200 AMP 13' JUMPER CABLES (A54756)
UNUSED 200 AMP 13'...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
HOBBS MODEL-666 6 ROW PEANUT RESHAKER (A54756)
HOBBS MODEL-666 6...
Skid Cropmaster Baler Twine (A50775)
Skid Cropmaster...
