beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,510
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
None of mine do
Safety first. Equipment can be replaced with a little $$$. People, not so much.Too many people lose hands and feet around mowers not to mention the ones that get struck by flying objects. Safety has to be the first consideration always.
This is (IMO) one of the few places where Cub Cadet beats Deere. You turn the key to the yellow position and push a button. Then you can mow in reverse until you shut the mower off.Still I think it's MORE dangerous to have that switch you have to pull before you can start backing up. I can't turn my head around and watch behind me while pulling that switch. I have a neck injury which makes it impossible for me but I think almost everyone would have a problem watching behind them while pulling that switch. Yet there it is ready for you to try.
The switch on the Cub Cadet LT1050 was fast enough that it shut the blades off and stopped them before the machine made it all of the way upside down the time I hit a wet patch while mowing around steep bank by the pond and slid over a bank.I love the switch on the seat that shuts everything off but the truth is if a mower rolls over those blades will still be spinning fast if you happen to roll right under the mower in a hurry. It's a good idea but it doesn't stop the blades fast enough. You may not get hurt as bad but you can still get hurt.
Slip the key chain or attached John Deere tag under the pto lever
