Engaging 4 wheel drive
   / Engaging 4 wheel drive #11
There cant be a bind when it is disengaged. -- Only a misalignment of gears trying to engage. I always engage mine while moving slowly straight ahead. Different tractor but should be the same idea.
larry
   / Engaging 4 wheel drive #12
A quick jerk is impossible since the lever won't move, doesn't matter if I put it into neutral, let the clutch out then try to shift it, the lever is really stiff. Once it moves the engagement is fine.
I just wanted to double check to see if you are doing this with the tractor running? It does need to be running.
Yes I tried it with it running and off. The lever just doesn't want to move easily, once I get it to move then it slides into gear with no problem.
   / Engaging 4 wheel drive #14
Hi Walt, I have had the same problem so I know how it is an aggravation when it doesn't want to move. Sometimes I have to try the clutch in and out twice, it seems to relieve the bind more. I finally got to where when I want to engage the 4 x 4 I jerk harder the first time. As long as the clutch is in the extra lift force pops it right in. There is probabaly some lube point that would help but I have never found it. Ray
   / Engaging 4 wheel drive #15
I've got a 1715 4 wheel drive, the lever that shifts between 4 wheel or not is getting pretty hard to move, any thoughts or recommendations as to what could be going on?
My 1715 goes in and out of 4WD rather easily. I use my foot to move the lever. If I'm on a hard surface, I can turn the steering wheel back and forth to relieve the wind up. On dirt, it comes out without any issues....
It could be a shift fork or damaged sliding gear.
NEW Landhero Mini Skid Steer Loader 23HP (A59000)
NEW Landhero Mini...
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
2013 HINO 338 26FT BOX TRUCK (A58018)
2013 HINO 338 26FT...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
1604 (A57192)
1604 (A57192)
