Engaging 4 wheel drive
   / Engaging 4 wheel drive #11
There cant be a bind when it is disengaged. -- Only a misalignment of gears trying to engage. I always engage mine while moving slowly straight ahead. Different tractor but should be the same idea.
larry
   / Engaging 4 wheel drive #12
A quick jerk is impossible since the lever won't move, doesn't matter if I put it into neutral, let the clutch out then try to shift it, the lever is really stiff. Once it moves the engagement is fine.
I just wanted to double check to see if you are doing this with the tractor running? It does need to be running.
Yes I tried it with it running and off. The lever just doesn't want to move easily, once I get it to move then it slides into gear with no problem.
   / Engaging 4 wheel drive #14
Hi Walt, I have had the same problem so I know how it is an aggravation when it doesn't want to move. Sometimes I have to try the clutch in and out twice, it seems to relieve the bind more. I finally got to where when I want to engage the 4 x 4 I jerk harder the first time. As long as the clutch is in the extra lift force pops it right in. There is probabaly some lube point that would help but I have never found it. Ray
   / Engaging 4 wheel drive #15
I've got a 1715 4 wheel drive, the lever that shifts between 4 wheel or not is getting pretty hard to move, any thoughts or recommendations as to what could be going on?
My 1715 goes in and out of 4WD rather easily. I use my foot to move the lever. If I'm on a hard surface, I can turn the steering wheel back and forth to relieve the wind up. On dirt, it comes out without any issues....
It could be a shift fork or damaged sliding gear.
HAMM HTC15 TRENCH COMPACTOR (A52709)
HAMM HTC15 TRENCH...
Pneumatic Grease Can w/Chevron Delo Starplex EP 2 (PARTIALLY USED - AIR HOSE REEL NOT INCLUDED) (A59076)
Pneumatic Grease...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A58375)
UNUSED I/A F10...
78in Quick Attach Smooth Bucket (A57453)
78in Quick Attach...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
