rear blade
   / rear blade #1
candyman
oh
Kubota 2011 MX5100 W/la844 loader, ag/ tires loaded, Massey Ferguson 2010 GC2610 TLB w/ r4 tires, loaded, 60" Belly Mower
we have a kubota mx5100 4 wd.need to get a blade for heavy grading one that tilts for ditch work, spreading gravel .
6 or 7 ft. suggestions. ?
thanks
   / rear blade #2
If it were me I'd get a quality 8'-er,for that tractor.
Boone
   / rear blade #3
I second the idea to getting a blade wide enough to cover your tracks when angled....not sure if this is 84" or 96" for your tractor. You should take a close look at the Land Pride RBT35 series. It will do everything you need including the ditching. For my JD5325 I purchased the RBT4096 last year with dual hydraulics(offset & angle) to use in maintaining an existing 1500' driveway and to shape a new 1200' driveway. I couldn't be happier with it. I seriously looked at Bison/Frontier & Woods. Bison/Frontier required side to side changeover of the piston on the offset. Woods was in the running but I felt the Land Pride had slightly better blade construction....Gary
   / rear blade #4
I bought a Land Pride RBT3584, all hydraulic. I just got it Saturday and haven't had a chance to use it yet, but is sure is heavy duty. It tilts, turns and offsets up to 30 inches.
   / rear blade #5
I concur look at the Land Pride RB35 Series, heavy duty unit and built like a tank.
DevilDog
   / rear blade #6
My Woods HBL96 is an excellent match for my 53 hp tractor. It's well built and tilts, offsets, and pivots any which way I need it to.
   / rear blade #7
A Land Pride RBT3596 with skid shoes would be the best blade available for your tractor. How many rear remotes do you have? I recommend that you have 4. 2 for top and tilt cylinders and 2 for the blade itself. One of those for angling the blade and the 2ND one for offsetting the blade. With that combination you will be set to do some major work. :thumbsup: :thumbsup: Please let us know what you end up doing. I know that I will be getting an RBT3584 :cool: as soon as I can afford one. :( ;)
   / rear blade #8
The manual Land Pride 3596 is my 'dream' blade but I know it cost over $100.
   / rear blade #9
You can probably add another zero to that $100 and still not be enough, which is why I don't own one...
David from jax
   / rear blade #10
For an all-mechanical (non hydraulic) blade, look at the KK HD series.
I have one (behind a much smaller tractor), but it is VERY HEAVY DUTY. And probabally cheaper than the landpride, woods, et. al.
King Kutter Heavy Duty Rear Blades
UNUSED FUTURE FORKLIFT TELESCOPIC BOOM (A51244)
UNUSED FUTURE...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2010 Toyota Corolla Sedan (A50324)
2010 Toyota...
