Mowing King Kutter finish mower GRINDING on PTO
   / King Kutter finish mower GRINDING on PTO #11
Are you positive it is a single clutch. If it is a dual and you take it to NH to fix it can get expensive in a hurry. If they replace the clutch and pressure plate assembly it is $2000 in parts. If they just replace both clutch disks the parts are arround $500. If it is a dual there are ways to unstick them. Do a search in this forum for stuck clutch and you will get plenty of ideas.
Bill
   / King Kutter finish mower GRINDING on PTO #12
Is it possible that the clutch linkage is simply out of adjustment? Most clutches have an adjustable rod running from the pedal to the clutch arm on the bell housing. If the rod is to long it may not be completely disengaging the transmisson. There should be instructions available for proper clutch adjustment.
   / King Kutter finish mower GRINDING on PTO #13
the owners manual has them...
   / King Kutter finish mower GRINDING on PTO #14
If you have a single clutch you adjust the clutch with the linkage.. If you have a dual clutch the pto clutch is adjusted internaly.
Bill
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2010 FORD F150 WORK PICKUP TRUCK (A51222)
2010 FORD F150...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
