Mowing King Kutter finish mower GRINDING on PTO
   / King Kutter finish mower GRINDING on PTO #11
Are you positive it is a single clutch. If it is a dual and you take it to NH to fix it can get expensive in a hurry. If they replace the clutch and pressure plate assembly it is $2000 in parts. If they just replace both clutch disks the parts are arround $500. If it is a dual there are ways to unstick them. Do a search in this forum for stuck clutch and you will get plenty of ideas.
Bill
   / King Kutter finish mower GRINDING on PTO #12
Is it possible that the clutch linkage is simply out of adjustment? Most clutches have an adjustable rod running from the pedal to the clutch arm on the bell housing. If the rod is to long it may not be completely disengaging the transmisson. There should be instructions available for proper clutch adjustment.
   / King Kutter finish mower GRINDING on PTO #13
the owners manual has them...
   / King Kutter finish mower GRINDING on PTO #14
If you have a single clutch you adjust the clutch with the linkage.. If you have a dual clutch the pto clutch is adjusted internaly.
Bill
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
EZGO (A50324)
EZGO (A50324)
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
