JC, How important is the quick lift to save you time? If you didn't use that you could try my top link chain on the brush hog to eliminate the binding you are getting from uneven ground. The chain replaces the solid top link on your 3 pt only for the brush hog, not for any other implement.
Food for thought here only. What do you think about making the top hat bracket wider, which would also allow a wider sun shade? My thoughts are if the bracket was wide enough to extend over the fenders on both sides and possibly as wide as the outside of the tires you could gain on the roll over protection to stop the tractor from flipping more than when the back tires are horozontal on the ground. To be more clear if you had a roll over the movement would stop when the rear tires were horizontal with the ground at the time the top bracket contacts the ground.
After reviewing pictures maybe the lift is hitting in a different spot that I thought it was. Is it hitting at the connection links that go down to the lower arms?
