Brushhog on fel
   / Brushhog on fel #1
Kaw
Member
Kioti dk55
So has anyone seen this,or can one from a skidsteer be mounted up on the fel. I did a quike search and found nothing.
   / Brushhog on fel #2
Why not? They mount them on everything else!!!
David from jax
I have one on a boom mower on the back of a 7710
   / Brushhog on fel #3
Kaw welcome to the forum. Generally the problem with using a mower on the front of a tractor is that the mower has to be hydraulically powered and most tractors will not have the hydraulic capacity to run one.
MarkV
   / Brushhog on fel #4
You would probably need to rig a hyd pump on your PTO.
   / Brushhog on fel #5
My favorite local rental yard rents skidsteer-mounted rotary cutters on
their Mustang 2044s. Or used to anyway. I have seen them, but I have
not operated them. One down side is you are driving right thru the cloud
of dust/debris as you mow.
Anyway, these units put out a lot of hydraulic hp, much more than your
usual compact tractor.
   / Brushhog on fel #6
MarkV
YUP!!
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A53472)
2009 Ford F-650 24...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53472)
2022 MAXXD BD14...
2019 Caterpillar 950M Articulated Wheel Loader (A51691)
2019 Caterpillar...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
