Brushhog on fel
   / Brushhog on fel #1
Kaw
Member
Kioti dk55
So has anyone seen this,or can one from a skidsteer be mounted up on the fel. I did a quike search and found nothing.
   / Brushhog on fel #2
Why not? They mount them on everything else!!!
David from jax
I have one on a boom mower on the back of a 7710
   / Brushhog on fel #3
Kaw welcome to the forum. Generally the problem with using a mower on the front of a tractor is that the mower has to be hydraulically powered and most tractors will not have the hydraulic capacity to run one.
MarkV
   / Brushhog on fel #4
You would probably need to rig a hyd pump on your PTO.
   / Brushhog on fel #5
My favorite local rental yard rents skidsteer-mounted rotary cutters on
their Mustang 2044s. Or used to anyway. I have seen them, but I have
not operated them. One down side is you are driving right thru the cloud
of dust/debris as you mow.
Anyway, these units put out a lot of hydraulic hp, much more than your
usual compact tractor.
   / Brushhog on fel #6
MarkV
YUP!!
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
Caterpillar Loader Quick Coupler (A53473)
Caterpillar Loader...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A53473)
Heavy-Duty...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
