Whats a good Planter ?
/ Whats a good Planter ? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Decided I would start learning about planters. In the past, Ive only used a seeder to broadcast food plots (beans in summer and oats in fall) I now have a good disk and tractor at my disposal and would like to become a bit more refined in my food plot installation. Also want to start planting a bit larger foodplots. Anyway, It seems a planter would be nice to get the beans / corn in a row for spraying or cultivating. What are some good 6-8 foot planters. (Brand and model #) thanks
/ Whats a good Planter ? #2
I'd look at a small grain drill instead of a normal row planter as long as you are doing full tillage.
Thirteen hole drills are readily available with good prices and have a variety of settings for most crops. To get one with the grass seed attachments would cover everything. To do row crops you just use magnets to cover the extra holes.
There are many makes and models that will do this and to look under the seed cover most have the rate charts right there.
/ Whats a good Planter ? #3
i would guess you need a two row planter.the rows will be 38 inches apart.you will not need row markers with a 2 row.you set the row spacing by running the tires over the tire tracks.the simplest is the cultivator planter set up made by covington.look up covington planters tp-46,that is what i grew up using.this would be the simplest longest lasting corn planter i know of.
/ Whats a good Planter ? #4
1st, as is the case with just about anything, you need to set a budget. How much are you wanting to spend....?
There are several good food plot drills available these days. Kasco Mfg in Shelbyville Indiana has a wide variety, but hang on to your wallet!!!! (We're talking several THOUSAND bucks!)
Row units are a good alternative. Since you're planting a variety of crops, you need a planter that can adapt to changing requirements. Most "older" planters are locked in to a range of row widths. As an example, the Deere 246 2-row planter...Decent machine, just time consuming to change row widths. Made to set at one width and leave 'em there, they'll plant between 28" and 44" rows. Personally, for what you're doing, I'd go straight to the Deere #71 (or older #70 unit) Flex Planter. With small seed cans, they can be set as narrow as 14". (Essentially infinitely adjustable on a tool bar) I plated 80 acres of soy beans this year with 7 #71 units set @ 15" rows. Got an incredible looking stand!
/ Whats a good Planter ? #5
I'm new to this too. Fwj that's 7 planters on a 71 planter? I've just seen two row. Would have liked to find a jd planter but this one came to us for good $. What are your thoughts on Allis chalmers? This thing is in good shape for $1000. My father and I are gonna do 37 acres in the coming spring. His best friend is a farmer so we lean on him for knowledge.
/ Whats a good Planter ? #6
That's 7 row units, set at 15" row spacings, on a tool bar that WAS a 4-row X 30" corn planter at one stage.
AC made some FANTASTIC planters, especially their first generation no till planters.
You guys have mentioned the model 71 planter. What is your opinion of the 7100 or the pull behind model 7000 in a 2 or 4 row version? thanks
/ Whats a good Planter ? #8
2-row 7000 series would be a cut down larger planter. (Deere never made a 2-row MaxEmerge planter) It would depend on WHO (how) did the work as to how good a modified planter would be compared to a factory built 4-row or larger.
You should be able to find plenty of 4-row factory MAxEmerge planters.
There were (are) more aftermarket accessories for those planters than any other brand/model in existance.
Down side to a 3-point model would be, 7000series are HEAVY compared to earlier planters. (#70's/#71's are relatively light in comparison)
From the research Ive been doing, it looks like cutting down larger planters into smaller planters is a pretty common thing. I would be using a Ford 7710 4wd tractor. If I used the 3 pt. 7100, im assuming I would want to go for a 2 row, and if I used the 7000, I could go with 4 row (due to weight). Do you think that sounds about right?
/ Whats a good Planter ? #10
It's common to cut down larger planters, but not quite as common with more modern planters like the 7000 series. You have plenty tractor to handle 4, 6, maybe even an 8-row if you had the urge....
/ Whats a good Planter ? #11
You could use a grain drill--my old, restored Minneapolis Moline P3-6 drill (10-ft wide, 20 hoes, single disc openers) will plant soybeans, corn, peas, common bean). I've only used it to plant Kanota oats. Use the large fertilizer box for the big size seeds.
DSCF0156 (Small).JPGDSCF0157 (Small).JPGDSCF0158 (Small).JPGDSCF0159 (Small).JPG
I bought two of these units for $275, used parts from both to make one working drill, spent about $200 for parts (mostly fasteners and a hydraulic cylinder to raise and lower the openers). Spent about 2 months getting the drill assembled and calibrated for oats and granulated fertilizer.
Food plot folks like yourself have spawned a market for old grain drills--small size (5-ft wide or so) obtained by cutting larger drills in half. I looked at these for my hayfield (which is only 6 acres), but these dwarf drills are still too pricy for my likes ($1500 and up on eBay, Craigslist, etc).
Good luck
/ Whats a good Planter ? #12
i would not recommend a cut down 7100 . a 4 row maybe.how much are you going to plant.a 7100 is a very good planter,but a lot of mantiance .i have owned several.if you do not want a covington .look for ih ,john deere or burch individual unit planter.if you plan to cultivate ,get one with row markers.it is hard to slow a grain drill enough to plant corn with it.
/ Whats a good Planter ? #13
I also have been eying the JD71's that come up for sale. Looking for 2 row unit. Not clear on whether the 71's come as no till vs till. If anyone has further information on the 71 planter, would appreciate it.
/ Whats a good Planter ? #14
most of the older ones have swords can not be used for no til .some of them have double disk openers good for no til.if you do not no til i think the covington 2 row set up is better for small acreage. a ford 7710 is really to big for 2 row.i would look for a 4 row wide{40 in spacing} or 6 row narrow{30 inch spacing}.
/ Whats a good Planter ? #15
An important difference between the 71 and 7000 type planters: The 71 row unit is ground driven from its own press wheel (the last rubber wheel that presses the seed row down at the back after the unit places the seed in the ground). And each row unit has its own press wheel. So the 71 unit is capable of being mounted alone, or any number together on a toolbar, 3 point hitch lifted. On the other hand, the 7000 type row unit is externally mechanically driven. Each row unit has a sprocket that must be turned by a drive chain to make the planter mechanism turn. On the typical four-row unit there are two or four implement tires touching the ground, supporting the weight of the toolbar, and picking up the drive power, transmitting the power via chain to a driven shaft across the width of the planter frame, allowing the power to be taken off by each row unit with another small chain.
If you think about it, cutting down a 7000 is way more work, because of this power distribution system. The 71 type unit does not need external power, just turn the press roller and the seed mechanism operates. I have seen 2 row 7000 planters that were cut from 4 or 6 row units, but they have to have that big implement drive wheel and all the other power distribution stuff, so are way more complex. Probably really nice planters though, as a 7000 is tough to beat for accuracy.
/ Whats a good Planter ? #16
I like messing with planters and drills. The older stuff is tough, and works good. First one I refurbed, was a 2 row A/C 600 series plate planter. It was simple to set up, rugged, used JD plates with an adaptor, and was HEAVY. Used it for several years, it's got a new home in SE Oklahoma. Found an old JD Model FB 15 X 7grain drill. Right side drive gears were stripped out on it. Decided I'd cut it down to a 7 X 7 for a food plot machine. It looks like it was made this size, and plants a mean rye or wheat plot. Next is a JD 2 row # 6 lister planter. This planter came from western Kansas. I thought the spoke wheels looked sharp. It's a mechanical trip lift, manual markers. Pretty cool old planter, works great. Found these JD 70 Flexi planter units. Built a toolbar for them that I hope to incorporated a fertilizer feeder on. I have 2 more I'm in the process of rebuilding. Replaced bearings, disc openers, scrapers, and seals on the disc opener bearings on the pictured ones. Now I'm working on this FB drill. It had a busted frame and lift clutch, on the right side. Started out as a 17 X 7. Now it's a 8 X 7, with working fertilizer and grass seed box. I think my favorite of all of them is the # 6 Lister. Believe it or not, the Allis Chalmers units are the newest. They were late 60s units, the 2 FB drills are 1950. the #6 is 1950, and the 70 Flexi units are late 50s. They plant the best, can adjust to about any row width, and are really accurate. Mark
Well, I have learned quite a bit from you guys regarding the differenced in the 70/71 and the 7000 series. Sounds like for my purposes (KISS) I would be better off with the older, more mechanical, possibly more reliable 71 units. Just so happens a local has a 4 row for sale. I talked to him this evening and he said he would take $500 for it. He mentioned that he kept it in the barn "all these years" and put it outside last winter. He said one of the boxes or hoppers, containers might need to be replaced. Could you replace the round metal containers with fiberglass units? Keep the information coming. I started from scratch with my knowledge of planters and Im learning lots from you guys.
/ Whats a good Planter ? #18
most of the older ones have swords can not be used for no til .some of them have double disk openers good for no til..
Only a few 70's and 71's came with runner openers. Even the very first 70's, sold in the mid 1950's were more commonly equipped with disc openers. You had to specifically request (order) runner openers. Disc openers were standard equipment on 70's and 71's throughout their production run.
Yetter Mfg, who built many of the 71's (under contract w/ Deere) bought design and production rights from Deere once Deere dropped the 71. Yetter still sells them, albeit a hefty purchase price.
70's and 71's are WAY too light weight to be considered as a no till planter. In "normal conditions" you would get very little soil penetration even with good disc openers, even with down pressure settings at their maximum. I know of people who have tried no tilling with 71's but they get VERY POOR seed depth consistency (Which is critical for corn)
All said and done, the #71 is still the most "adaptable" plate type planter ever built. Most seed corn growers used them well into the late 1990's, as it was VERY gentle with seed, VERY accurate with seed placement, and VERY easy to set seed rates, spacings, ect..
/ Whats a good Planter ? #19
the older john deere planters we used before the 7100 max emerge had sword openers.i do not remember the number .all we used to plant was cotton around here.maybe the local deere ordered all of them with sword openers .
/ Whats a good Planter ? #20
If that 4 row planter is 71 units, in decent shape, I'd be all over that like a chicken on a June bug! :D Parts are still available from John Deere (Yetter too), they're simple to work on, rebuild, set up and use. You can find the seed boxes on ebay fairly often. Definately NOT (IMHO) a no-till planter. For the price of a 7000 or 7100, you could probably get that 4 row your local has, and a good old drill. Then you can plant your plots in anything you want. Mark
