Welder suggestions
   / Welder suggestions #1
tooln
North Central WI
Kioti DK45SE-HST
I'm looking to buy a welder for home. I'll be doing nothing heavy with it. Up to 1/4" would be the max. I've used a 120 volt Miller for TIG welding in the past and it worked slick. I've been asking around for suggestions on a MIG 120 volt unit. Most people tell me don't even bother with a 120 volt for MIG as it will be to small for anything but sheet metal. Does anyone have any suggestions? Does anyone use a 120 volt for MIG if so what size and make. Does it work for you? I finally found me a good usable ezee flow drop spreader and I'm going to cut it down to 6' wide for my food plots. Thanks
   / Welder suggestions #2
I'm one of the ones that would say to stay away from the 110V models. For body work they can't be beat so they do have their place but I wouldn't get under a 180A model. There's going to come a time when you want to weld something heavier and the small machine just isn't going to cut it. My 2 cents worth.....Mike
   / Welder suggestions #3
Northern Industrial 125 Flux Core Welder | Wirefeed Welders | Northern Tool + Equipment
I have this, I really have found it to be easy to set up and use. I make tow behind tractor toys for my daughter. The frames are 1/8'' angle iron. The welder is perfect for this and if property preped I am sure I could do 1/4'' I went with the welder I would use most, and compared it to what was in my wallet. When I did this model was tops for me. It came with the 10lb spool attachment so i havent had to swap out a spool yet.
I shopped for about 2mts before I bought this one. I looked at all the name brands, recondidtioned etc. I am very very happy with this model.
   / Welder suggestions #4
Miller autoset 211
115v and 220v
Portability of a small machine with performance of a bigger unit!
Also available as an option is an aluminum spool gun
No I don't work for or sell Blue but do think this would fit the bill
   / Welder suggestions #5
you might get by using fluxcore .i would get one with at least 140 amp .i have used lincoln and miller i would recommend them.220 is better.hobarts were on sale the other day at tractor supply.
   / Welder suggestions #6
ericher69 said:
Miller autoset 211
115v and 220v
Agreed. I have a 211 and it is great. It's big enough for what I need and will still run on 110 if that's all I have to work with somewhere. I got a pretty good deal on eBay for the welder, spool gun, and a little tackle box full of consumables.
   / Welder suggestions #7
Miller autoset 211
115v and 220v
I have one and weld sheet to heavy stuff around the farm and it does the job! Have a tomb stone also and use it on breakdowns in the field with a generator!
   / Welder suggestions #8
I'll have to agree with the Miller 211.
The option of 220v or 110v is very apealing to farm/ranch work. A great companion for the Miller 375 Plasma Cutter that is also a dual voltage unit.
However I still keep the o'l arc welder to do the heavy repairs...
Looks Like I'll end up spending more than I really wanted but it will work for me. I'm leaning between a Millermaticョ 211 Auto-Set with MVP or a Hobart Handlerョ 210MVP, with Multi-Voltage Plug. Over the weekend I'll shop around on-line & once the Holiday is over I'll go to my local supplier and see what kind of deal I can get.
   / Welder suggestions #10
Lincoln is running a special on the 140c for $600.
2008 Nautica International RIB 24ft Cat Boat (A50324)
2008 Nautica...
71064 (A49346)
71064 (A49346)
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
2013 CATERPILLAR 320EL EXCAVATOR (A51242)
2013 CATERPILLAR...
Set of Tractor Tracks (A50514)
Set of Tractor...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
