Carrying chains???
   / Carrying chains??? #11
OK, here is a weird one. 1/2" solid square stock 10" long. A 2" piece of it welded parallel to the bottom and to the brush guard. It makes a "U" with very long verticals and only 1/2" between the verticals.
The chain links slide between the brush guard and the square stock. It should take about four or five loops and will not slide out. Three units will be welded onto the brush guard for three chains.
One caveat - I have all of the materials but with 111 degree heat index the project is being put off. It may end up being a total failure but it seems like a good idea in theory.
Reason: The chain used to be wrapped around the top of the forks where some 2" x 1/8" framing is used as guard. The chain came loose and, unnoticed, got caught under a front tire while carrying a heavy load. The framing ended up like a pretzel. Some 2" x 1/4" bar will be used to rebuild it when the weather cooperates.
I thought about welding the chain carriers on the new forklift frame but the range of motion would allow the chain to slip out of the square stock carrier.
   / Carrying chains??? #12
I let mine drag behind the tractor. Then if I get lost, I can just follow the line back to where I started. It doesn't always work though. Once I drove in circles for 2 days.
But, I do like the PVC container. I'll be making one of those. :thumbsup:
   / Carrying chains??? #13
I made a chain box from scrap that sets inside the factory grille guard on my JD 790. Then made a "improved" grille guard the covers the factory one, hooking onto the chain box & one pin through the top pipe of the factory guard. ~~ grnspot
   / Carrying chains??? #14
Much the same as JW 5875 but I used an old 4" or 5" Dia. fire extinguisher. Just cut off the top and drill a hole in the bottom to drain the water.
I welded a 3/8 '' Dia. rod. across the top to hang the chain on but they can hang on the side as well. By using a steel tube or whatever it makes mounting easier as you can weld on brackets to attach to tractor or loader frame as needed.
Al
   / Carrying chains??? #15
I bolted on a small piece of square tubing and welded on a small hook on the bottom.
   / Carrying chains??? #16
I wrap it around my front counterweight and hook the ends to the inner loops of chain so as to not lose it. Came loose once when grading, but all it did was drag, now I secure the ends with a bungee cord.
   / Carrying chains??? #17
I let mine drag behind the tractor. Then if I get lost, I can just follow the line back to where I started. It doesn't always work though. Once I drove in circles for 2 days. :
:laughing::laughing::laughing:
Sounds adventurous. I think I'll borrow that idea.:cool2:
I like the PVC tube idea. Bob's welded-on square tubing is good, too, but the tube keeps it more contained and not swinging around.
   / Carrying chains??? #20
...and scratchin' that purty green paint. :)
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
