1983 YM336D - How bad is this? Worth fixing? (warning: graphic images of broken bits)
   / 1983 YM336D - How bad is this? Worth fixing? (warning: graphic images of broken bits) #11
So far things have been progressing along nicely, until now..
Any tips? advice?
How difficult is it to crack this housing open to diagnose/fix this?
Hold On Domush. I'll scan in some pictures from the parts manual when I get home tonight & send them along. You are shortly going to be the mechanical 336D guru.
rScotty
that filter almost looks to be rusted out, it has had water in it for a loooong time i'd say. the hydraulics for the 3PH have prolly rusted up.:(
It does have some rust flaking in the upper assembly, but not too bad. The filter cleaned right up with a garden hose. It looks nearly new, now. Today I took the top end off the hoist and removed the hydro head and lift assembly and both seem perfectly fine, o-rings included. I'm beginning to wonder if the filter being clogged pretty much completely was the cause all along. The loose parts on the bottom pan didn't seem to impact the hydraulics any, which is a small miracle on its own.
You do understand that the broken bits that you showed have nothing to do with the hyd not working.
Yep, I do, and I'm doubting those parts even impacted the hydro system, as they simply set on the bottom near the filter. Either way it needs some fixing. I'll be starting on the axle removal tomorrow, as long the rain holds off. Hopefully extracting those bolt heads won't be difficult, but if they are, I'll just bring the two axles to the metal shop and weld a couple of temporary heads on them so I can really crank on them.
I just happened to fix the hydraulic lift problem on my 169D about a month ago. It actually isn't that hard to do. First thing I did was tested the hydraulic pump which came out okay. So I pulled the top housing off the transmission which houses the cylinder that lifts the hitch up and down. Pulled out the cylinder head and there was a O-ring around the cylinder head that was dimpled and shot. $4 and a trip to Kubota was all it took, they are more likely to have the right O-Ring since John Deere doesn't carry these O-rings in stock and don't carry the right size. The O-ring is critical, with a small gap in it this allows the pressure from the hydro pump to escape and just go into the transmission.
Glad you have done this fix already. Always nice to find someone with recent experience on it. I removed the piston and found the o-ring to look really healthy. I'm not exactly sure if what I see as healthy is not worn out, though. Do you happen to have the part # of the o-ring you got? I'm betting Yanmar used the same size piston. I'll bring Kubota the piston to size it just in case. For $4, it'll be the cheapest part so far.
I would have been happy too if I could have found it but my crappy photo copied manual the pics are horrible in it makes me wonder about when I need it for me. :mad:
One thing I did notice while looking for those parts is that tractor has a built in pto overrun clutch. Maybe all us models did I dont know but that is pretty neat feature not as easy to repair as an add on but doesn't make you shorten a drive shaft either for an attachment.
I have the factory service manual, so if you ever need a scanned page or three, let me know. I'm happy to help out.
I noticed the PTO overrun clutch when playing around with the PTO shaft. I thought that was what I was looking at, but doubted myself, seeing as everything about this tractor is new to me. Yaya for better than expected items! :thumbsup:
That clogged and rusted filter could be 90% of your problem. I would open it up and look around.
The filter sure was filthy! Luckily it cleaned up REALLY easily (garden hose). It looks good as new, now.
rScotty
You are awesome! Thank you! I have the thing apart quite a bit, but I have no idea what I'm getting into splitting the rear axle in two (three if you include the trans). The first issue is figuring out how to remove the rear rims, as the lugs are so tight my Ingersol air impact driver can't even budge them, which is a first for my impact. Getting into the big leagues when it comes to tools, I guess. :eek:
Tomorrow I'll also be welding a new lift dampening valve onto the height adjuster, as the current one is missing the lever (broken off). There is a roll pin hammered right next to the bolt holding the dampening valve, so I can't unscrew it or remove the roll pin, so I'll be welding a new handle while the dampener is still installed, which will be scary.
I'm excited to see those scans. The service manual doesn't open up the hydraulic assembly beyond the pump and filters or even mention the rear axle.
   / 1983 YM336D - How bad is this? Worth fixing? (warning: graphic images of broken bits) #15
When I bought my 2500 diesel truck & my tractor. I found I had to upgrade my impact wrench. I had to buy 1 that provided 625 lbs of torque to be able to remove & install nuts & bolts
I found the parts which broke off. I'm still have no idea as to how these bolts would have broken, especially on both sides.
attachment.php
BTW, #65 is technically a washer, but is really a 3/8" steel plate with three holes in it. #66 is a tabbed nut lock which keeps the bolts from unscrewing (which it did valiantly). #71 is the bolt itself, of which there are 3 on each side, all broken right off. 3 bolts broke at the head, 3 in the middle of the threads. I'm not sure, but it seems as though the wheels should slide right out of the axle housing, which I'm more than a bit shocked hadn't happened during loading/unloading on the trailer and around the street when I bought it.
   / 1983 YM336D - How bad is this? Worth fixing? (warning: graphic images of broken bits) #17
Did the manual originally look like these pictures? I'm not too keen to take mine apart & scan it in...
rScotty
The PDF seems to be the original Yanmar e-version, as it is fully organized and great quality. I'm thrilled! I still don't know what broke my parts, but at least I can work on it with much less worry, now. :thumbsup:
   / 1983 YM336D - How bad is this? Worth fixing? (warning: graphic images of broken bits) #19
Yes, I'm also the kind of guy who also finds the parts manual to be the most useful book for working on things.
Yanmars have very hard tough gears made of top quality alloy steel. It wouldn't surprise me to see those gears prgressively grind off a mild steel bolt just like a milling cutter will do and end with no damage to themselves at all. Those parts came from a quality era.
rScotty
   / 1983 YM336D - How bad is this? Worth fixing? (warning: graphic images of broken bits) #20
That's amazing. How did you get a parts manual in PDF?
rScotty
Just stumbled accross it. Actually came from Australia. I think there is another one or two out there on the stateside models. None on grey market tractors I have seen.
UNUSED FUTURE D45 HYD POST DRIVER (A51248)
UNUSED FUTURE D45...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53472)
2018 Link-Belt LBX...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2018 BIG TEX 70CH 84" X 20' CAR HAULER TRAILER (A51247)
2018 BIG TEX 70CH...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
