HydrauLink- a self-contained air over hydraulic top link
   / HydrauLink- a self-contained air over hydraulic top link
I have a cat 1 tractor (Kubota L-3010) but I need a LONGER top link.
Should I get an extended screw for a cat 1 link OR will the cat 2 link work AND be longer?
Thanks:confused:
Both of these products are now in-stock so I guess it really boils down to what length you need and how much weight you need to lift. Your tractor likely uses a category I hitch but a cat II will work if you use a sleeve to compensate for the differential. Those are cheap. I've attached a copy of our latest flyer with measurements on it for you to look at. Look at see what fits your needs best.
If I had to hazard a guess, I'd go with the cat I and an extended screw.
Your pin diameter is the easiest way to determine what category your hitch is. I believe:
cat 0=3/4" cat 1=7/8" cat 2=1 1/8" cat 3=1 7/16" on the top link. I could be wrong.
You're right. Although I've found that some of the differences in diameters varies a bit depending on the manufacturer. Still, you've got the right idea.
   / HydrauLink- a self-contained air over hydraulic top link #403
Tks high compression, guess I have a Cat II then as my pin diameter is 1 1/8.
   / HydrauLink- a self-contained air over hydraulic top link #405
You're very welcome. Glad I could help.
   / HydrauLink- a self-contained air over hydraulic top link #407
I'm in need of an answer regarding Hydraulink and the float control on UT's 50hp and up for ground engaging equipment (plows, disks, etc). Is the float control and the Hydraulink compatable. If so, which unit takes control the most. Or are you not using the Hydraulink for ground engaging attachments? Any info from expeirence would be helpful. Do not reply with theory. Facts with results only.
Thanks,
idaho2
   / HydrauLink- a self-contained air over hydraulic top link #408
Hydraulink,
I had lost track of this thread and just caught up with it- Congratulations! It looks like you have hit the critical mass (after the mass criticism) and have some serious distribution as well. The US needs more innovators with the spheres to see their ideas thru. I just hope you are manufacturing it here.
John
   / HydrauLink- a self-contained air over hydraulic top link #409
I just purchased one of cat 1 and to my surprise when I pick it up it says made in china on the box
One of reasons I bought this was for American product I have enough china products already
If it was to keep cost down should be other ways
   / HydrauLink- a self-contained air over hydraulic top link #410
Just called the company, and guess what, they said they were originally made in USA, they are now Made in China.
Now if this is true, why did the price not decrease.
This is a copy of post #1 Bottom line says Made in USA
What sets HydrauLink apart?
* HydrauLink is completely self-contained
* No pumps or external hydraulics are needed
* Makes small adjustments automatically while you work, reducing time on the job
* Acts as a shock-absorber for implements, making for a noticeably gentler ride
* Larger adjustments can be made without leaving the cab
* Improves safety by eliminating the need to be behind the tractor while its running
* Installs in about three minutes by one person
* Can be moved from one tractor to another quickly and easily
* Comes ready to work out of the box.
* ISO 9000 certified
* Made in the USA
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
2023 John Deere Z994R (A50121)
2023 John Deere...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
Skid Mounted Controls (A50121)
Skid Mounted...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
