Lifespan of a fencepost?
   / Lifespan of a fencepost? #11
"Like" landscape timbers or were they actually landscape timbers? Those are not really made for direct burial. I think they are treated to 0.25 where normal pressure treated is 0.4 and marine grade pilings is treated to 0.8
Landscape timbers are not the same thing as treated fence posts. I have treated fence posts, set in concrete, that are still strong after 25 years. The only thing that I have seen rot them out quickly is if you cut the tops of them off. If you trim 6" off the top of a treated fence post it will rot out in less than two years.
   / Lifespan of a fencepost? #12
Hmmmm. Coincidental to what I was doing today.
After putting the fence in 3 years ago with 9 foot treated 4x4's, then re-doing it last year (don't ask) with a post driver with 10 footers, I finally got around to trimming the tops off today, to correspond with the top of the fence.
As it turned out (the wind helped), I was able to enjoy the scent of the wood as I cut through the tops with the recip-saw. It was at that point that I realized that some of the treated posts were in fact, cedar, whereas others were spruce or some other soft wood.
I know I bought all the posts at one spot, and certainly didn't pay 'cedar' prices, so it proved once again that you can never be sure what you're buying, particularly if it's been treated, disguising the wood underneath. :confused:
If I'd known the supplier was selling treated cedar, I would have been a lot more selective when I was picking them out of the bin. :thumbsup:
   / Lifespan of a fencepost? #13
Oh yeah, for the record, I'm going to Home Depot tomorrow to get preservative for the top of the cut posts. Thanks for reminding me...:D
   / Lifespan of a fencepost? #15
In 1982 I redid a number of 6'fences using pressure treated posts from HomeBase... a chain like Home Depot.
Back then, each post came with a warranty tag and almost 30 years later I have not had a single post issue...
Too bad, the posts today don't have the same warranty and cost 2.5 times as much.
They were all set with concrete mix.
   / Lifespan of a fencepost? #16
interesting topic.
I have been removing fence on my 100+year old dairy farm in areas. It is interesting to see the different types of posts that were used. Mixture of telephone (some carry the C&P tagging), natural cedar (rough cut), pressure treated (round, and square) and even T-posts.
Based on soil conditions around the property, the natural rough cut cedars have out lived all others. They sort of flake off in the ground contact areas. They get wobbly, but hold their own. The telephone poles are next up, but only due to their size. The pressure treated wood, held up well, but I doubt I'll find that treated material again. The T-post, well it should not be around a creek bed. Mother nature rearranged the creek over time and I have had to fish a lot out of the water. The rest of them just sort of fell over, freeze/thaw, animal and machine contact I imagine.
   / Lifespan of a fencepost? #17
Don't feel bad our landscape tembers did not last here either..Terrible fence post and terraced stacking did not hold up either? Maybe they just spray on the treatment, never did see any references to "Pressure treated"...But the price was way below, the cresoted fence post?
   / Lifespan of a fencepost? #18
About two years ago, we had roughly 4 acres fenced with treated wooden posts, roughly 4x4", with rounded corners like landscape timbers.
When you replace the posts, check the top and/or bottoms if you can. All of the PT wood I have ever bought from Lowes, HD or better yet, directly from a PT company, as a label stabled to the end of the lumber. You might find the label in the post hole if you reuse the holes. The label has the PT treatment content. My guess would be that the wood used was treated at .20ish PCF and not rated for ground contact. The posts should be at least .40ish PCF or higher.
We have lots of Red Ceder here and I see it used for fence posts and even pole barns. The stuff rots out pretty quickly from what I can tell though it takes a good decade or two before the fence or barn completely fails. We looked at some property that had been owned by one family since the late 1800s. The guy selling was the last surviving sibling who had been born in the farm house his dad built in the early 1920's. They had numerous out buildings and barns using rock foundations and Red Ceder sill beams. Those barns were still in great shape because the ceder was not touching the ground. The rocks and ceder where found on the place.
Later,
Dan
   / Lifespan of a fencepost? #19
Later,
Dan
I agree. I think the treatment on those posts is light. Our green [pine] posts have lasted well at 12yrs and counting. Cedar seems to rot down to the heartwood in a few years and then stop. If the post has a big heart you can tamp it back tite and go a looong time. Were replacing the small hearted ones were having to remove with the treated pine driven down the same hole. They have moved away from the arsenic treatment to another preserver. I have no experience with how it compares, but Im hopin.
larry
   / Lifespan of a fencepost? #20
Same here, 25 years old http://www.tractorbynet.com/forums/attachments/projects/146222d1258730980-board-fence-img_3949_1.jpg
I would not want to look for stuff today that would last 25 years.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2015 Kubota RTV-X1100C (A52748)
2015 Kubota...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
