What is your most used implement?
   / What is your most used implement? #51
1. rfm
2. rear blade
3. tiller
4. 3 pnt forks
5. boxblade & landscape rake are probably tied
6. sprayer
7. trailer hitch
   / What is your most used implement? #52
In this order:
FEL
Tiller
Sprayer
Rotary Cutter
Planter
Box blade
Landscape Rake
   / What is your most used implement? #53
MtnViewRanch said:
What is the difference between an attachment and an implement? :confused:
Let me clear this up...
Is it a soda or a pop?
How about a sack or a bag?
A grinder or a sub?
Don't look too deep when it's just two words that man the same thing...
   / What is your most used implement? #56
i know i dont have a front end loader but wonder what yall folks are doing with them so much that you use them more than a cutter? I live on a small peroperty but also have a large property that i hunt on and go to maintain it. I still have not missed not have ing a loader yet? Maybe its cause i have a boom pole to lift things but im just wondering what are you guys with 5-10 acres doing with your loaders, let alone what are you doing on your tractor all the time. I put maybe 50 hours a year on bushhogging my fields and planting a few acres max of food plots a year. I bushhog maybe 7 acres 3 times a year maybe less?
Just curious, i dont live on the property so if i did i would cut it more. Not haveing cows and not moving dirt etc i cant see where it would be used much (FEL)?
   / What is your most used implement? #57
Lets see in the last 2 days I moved a few totes of halibut, same of ice, a skiff, bottle of argon, many loads of gravel, a few pallets of line/anchors/bouys, and probably about 20,000 lbs of kelp and that is just the things I can remember and I have CRS really bad.
Rick
   / What is your most used implement? #58
5' Woods finish mower, the loader , rear blade & brush cutter; in that order!
   / What is your most used implement? #59
Front end loader then MMM. After that there are prlenty more but these two use up 90% of my seat time.
   / What is your most used implement? #60
I use the FEL the most just finished 30 ton of 2b.Getting ready for 10 ton of stone chips for pavers.The next would back blade and toothbar.
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
TORO MBTX2500 STAND ON DUMP BUGGY (A52705)
TORO MBTX2500...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
Frontier FM2015 (A53314)
Frontier FM2015...
