Tires for 10 ton trailer?
   / Tires for 10 ton trailer? #1
Heavyduty
Gold Member
I need to replace (8) :( old, dry rotted tires on my 10 ton trailer that I use to haul my equipement. Been using the Michelin LTX load range E on my 15 inch steel rims. Any thing better then the LTX's I bought 5 yrs ago? I never seem to wear tires out but the sun gets to them.
   / Tires for 10 ton trailer? #2
15" rims on a 10 ton trlr?
If you load heavy, go for as high ply (load rating) as you can find. I run 14 ply on a 10 ton.
What name tire and rim combo are you running?
I know 16 in. rims would be better but I would think it would cost more than the trailer.:laughing:
   / Tires for 10 ton trailer? #4
If you are running 15" wheels on a 10T I would get some Greenballs. They make the best trailer tires on the market. I know they have 8 plys and maybe some 10 plies also.
I have bought no less than 100 of the Greenball ST 225/75/15 load range D and have not had one single failure.
Like you said, 5 years is about all the life you get out of tires unless they are out of the weather and sun.
Chris
   / Tires for 10 ton trailer? #5
It's a dual tandem that has a regular "Budd" style wheel, and the tires are Hankook.
Chris
How much total weight are you hauling?
   / Tires for 10 ton trailer? #7
My lightest current trailer is a 7,000# car hauler with 205/75/15 Greenballs on it. Had Goodyears and after multiple failures in the first 2 years I switched.
My other two trailers are 9,680# and 15,600#. Both have 225/75/15's but the larger is a tri-axle.
I can not tell you how many sets I have put on for customers for trailers ranging from 7,000# to 18,000#. Safe guess is 25 sets of 4 or 6 since 2002 when I discovered them.
Not one single failure.
Goodyears and Carlises we had tons of failures with. Carlises were the worst and the Goodyear Marathons not far behind.
Chris
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2298 (A58376)
2298 (A58376)
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2019 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2019 John Deer...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
