what the heck, ac mig welder
   / what the heck, ac mig welder #11
I'm wondering if the label on the HF is wrong. I'be measured mine and it's DC. It's one of several that I own and has worked quite well. Bought it over6 years ago. Made one mod to help with with the low duty factor by adding a fan. Don't get me wrong it's not my primary welded but it has come in handy for fixing things like gates etc. Just use good quality wire as HF wire is crap.
I would not buy a welder from princess auto, I dont trust anything electronic, or saftey related from there. The powerfist ones are listed as AC, and so are some of the harbor frieght ones, so they are useless. If I get a mig it would be a lincoln.
Shield Arc, does the SA-200 have plugs on it to run a grinder or drill? If so, are they DC or AC.
   / what the heck, ac mig welder #14
Yes they have a 120-volt plug, but they're DC ONLY! The older models with vacuum idlers, the idler has to be pinned so the engine stays at high RPM. There is a grind-ease option you can install that will kick the RPM's up to high when you start to grind. I have one SA-200 that has an electronic idler, it will kick up to high RPM when you start to grind.
OK great, the DC ony is fine, I have some very old industrial drills that can run on dc, and I think my 7 inch grinder can as well ( I will have to check that).
   / what the heck, ac mig welder #16
As far as value goes, Hobart has really become a good brand to own again over the past 10 years.
Dave
Ya hobart is a really good value, but I dont know of any dealers of them here. (other then northern tools, but shipping from the USA is a pain)
   / what the heck, ac mig welder #18
Praxair or Napa should have hobart. If theyre handy
As I said, I am not needing a mig welder right now, but when I do, I will take a look at hobart.
Cummins Onan 35EK (A47384)
Cummins Onan 35EK...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2017 Ford Transit 250 Cargo Van (A50323)
2017 Ford Transit...
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2022 DYNAPAC CA3500D SMOOTH DRUM ROLLER (A51242)
2022 DYNAPAC...
