Whats with you guys and ballast boxes and rear weight implements.
   / Whats with you guys and ballast boxes and rear weight implements. #41
The biggest difference is, as other have posted, he has a full size tractor. Far more comes into play with stability than just the weight of the tractor and what, if any, ballast it used. For instance wheelbase, center of gravity (both hrz and vrt), attachment point for the loader, tire type, etc.... These factors also come into play as far as axle load/stress is concerned. CUT's and SCUT's have short wheelbases and the loader attachment point is often closer to the front axle relative to a full size tractor. Hence the reason they tend to need ballast more often and may have higher rates of front axle failures due to loader work.
   / Whats with you guys and ballast boxes and rear weight implements. #42
The OP wasn't asking a question that he wanted an answer for. He was either throwing a bone out there that folks would fight over, or making fun of those that do things differently than he does. We have answered each other's questions, but not the issues of the OP.
   / Whats with you guys and ballast boxes and rear weight implements. #43
   / Whats with you guys and ballast boxes and rear weight implements. #45
Oh...trust us...we can make a long thread about any subject...
But it sure seems when the topic of ballast is involved it really stirs alot more interest.:)
Greg
   / Whats with you guys and ballast boxes and rear weight implements. #46
not this again!
   / Whats with you guys and ballast boxes and rear weight implements. #47
Greg
Especially when the topic strays to ballast on HST vs Gear Cabbed or OS tractors...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2006 International 7500 Asphalt Distributor Truck, VIN # 1HTWNAZTX6J383773 (A54865)
2006 International...
2007 Hyundai Sonata GLS Sedan (A55853)
2007 Hyundai...
EZ-GO Electric Cart (A55853)
EZ-GO Electric...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND68FDGH1824 (A54865)
2015 Freightliner...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
