Pole Building (Gizmo2) 20X32
   / Pole Building (Gizmo2) 20X32
Doors are on. I will do the concrete in the spring.
   / Pole Building (Gizmo2) 20X32 #22
Beautiful. I remember now you asked awhile ago about what kind of doors to use. I think the carriage doors were a good choice.
When you say they put 2 bags of sakrete in each hole before the biscuit, do you mean dry?
Thanks BeezFun.
Yes, 2 - 80lb bags of Sakrete in each hole then the 7" x 18" biscuit.
I thought to myself at the time "I would not have done that, not in a million years". I guess the Sakrete helps to level the bottom.
   / Pole Building (Gizmo2) 20X32 #24
They could put gravel in the bottom to level it. Do you think this is some kind of code requirement? I've heard of mixing sakrete and water in the hole, and I've heard of using it dry if there's water bleeding into the hole, but I've never heard of using it like this.
The last 2 pole buildings I've done I put 2 bags in each hole dry, also. The sakrete will harden from the moisture in the ground. But I have never used the so called biscuit. I like the whole idea of the way they did it. I guess the company that put up my building has been in business for a long time and the crew here said they have never had a problem with the way the poles are set in the ground and why mess with what works. I said COOL!:D
   / Pole Building (Gizmo2) 20X32 #26
Hey Gizmo,
Really like your building and how fast it went up.
About those biscuits, did they put those over the hole and insert the pole through them? I couldn't tell from the pictures, but I assume they were the round concrete pads with the square holes in them.
Mike
BayouMan,
Thank you.
Nope, the biscuits are solid. I think what you see in the picture is something on the plastic.
   / Pole Building (Gizmo2) 20X32 #28
So did they put the biscuits in the bottom of the hole? Just curious since I am always interested in different techniques.
Thanks again.
Mike
Lights are done inside and out.
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
