The tractor split-teh
After 5 hours of swearing and hating life. We split the tractor to expose the vaunted dual clutch. After reading Mike Wards post, I expected my old clutch to be trashed. However, it didn't look that bad. What do you guys think? The PTO was stuck (free play adjustment and blocking didn't loosen it) so I wanted to change it anyway. But, I'm wondering if I really needed to now. Maybe some finger nut adjustments could have helped.
A few lessons learned (first timer mistakes):
* Renting a steering wheel puller is useless. Use a 2x4. Leave the nut on just a bit for leverage. Spray some PB penetrating oil on it.
* The input shaft moves. Dont keep pulling the tractor apart and watch it stretch.
* Be very careful in removing the hydraulic connections for the remotes. I didnt ruin any, but I was on pins and needles when we began splitting.
* The 7108 loader manual, lies. There is no 5/8 nut to open the lower latch. Try 1 friggen inch. And, it may be paint-stuck. Get some heat and impact wrenches.
* All the weight on the rear of the tractor is near the front, not behind the tires. It dropped forward a bit and freaked us out.
I didn't get a new PTO disc although my bargain basement clutch said it supposed to come with one. I'll get that straightened out before assembly.
The throughout bearing looked rusted, but moved smoothly. Replacing that too.
Lastly, my input shaft seems bent slightly. I rolled on the concrete and it wobbled. I think I may have done that in splitting it. I'm going to try to replace that too.Thanks for the advice guys. I would have never tried this without some of the great information posted here.
P.S. JC
The new clutch seems to be cast iron. I'm a bit unsure. The finish is smooth and no loose shards or reman signs. Perhaps this is an aftermarket. There is no core charge for the old so I'll disassemble it and post some pictures
P.S. JC
