Long 460 dies after about 30 minutes
   / Long 460 dies after about 30 minutes
the injector pump was replaced a year ago. what i am calling a fuel pump looks like what is pictured if you follow the link below.
http://www.brokentractor.com/images/tx10289.jpg
   / Long 460 dies after about 30 minutes #12
I once had a similar problem, it was caused by crud in the fuel line blocking a fitting called a banjo fitting where the fuel line connects to the pump with a fitting that a bolt goes through the middle. There is a small hole through the bolt that was plugged up.
   / Long 460 dies after about 30 minutes #13
there is a good possibility the banjo fittings are clogged. i will go ahead and replace the "pump", or whatever it is called and possibly the filters
   / Long 460 dies after about 30 minutes #15
post back what ya find.
soundguy
i'll be on it monday morning and letting you know
here is what i did: blew out the lines and bled the system and it runs like a top again. thanks
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
John Deere 702 Hay Rake (A50515)
John Deere 702 Hay...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
