Long 460 dies after about 30 minutes
   / Long 460 dies after about 30 minutes
the injector pump was replaced a year ago. what i am calling a fuel pump looks like what is pictured if you follow the link below.
http://www.brokentractor.com/images/tx10289.jpg
   / Long 460 dies after about 30 minutes #12
I once had a similar problem, it was caused by crud in the fuel line blocking a fitting called a banjo fitting where the fuel line connects to the pump with a fitting that a bolt goes through the middle. There is a small hole through the bolt that was plugged up.
   / Long 460 dies after about 30 minutes #13
there is a good possibility the banjo fittings are clogged. i will go ahead and replace the "pump", or whatever it is called and possibly the filters
   / Long 460 dies after about 30 minutes #15
post back what ya find.
soundguy
i'll be on it monday morning and letting you know
here is what i did: blew out the lines and bled the system and it runs like a top again. thanks
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A51039)
2022 Quick Attach...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
