Air hose 1/2 vs 3/8 - ?
   / Air hose 1/2 vs 3/8 - ? #1
9973720wb19
East Coast
Many
I have an IR 60gal 5hp compressor. most of my tools are 1/4 inlet and I've been using a 3/8 hose. what size hose do most of you guys use?
   / Air hose 1/2 vs 3/8 - ? #3
As Above , All I have anymore is 3/8" except for my large impact wrench which I have a 1/2" hose for . Unless you go on a super long run , ( over 100' ) , 3/8" carries enough air for just about anything .
Fred H.
   / Air hose 1/2 vs 3/8 - ? #4
I have 3/8 hose but have changed my couplers on all my tools to 1/2 (I think, 1/2; maybe they are 3/8 couplers but definitely larger than the standard 1/4). I found that the bottleneck was the 1/4 couplers and fittings. Going one size larger delivered much more air to the tool without the need for the larger hose.
   / Air hose 1/2 vs 3/8 - ? #5
I have 3/8 hose but have changed my couplers on all my tools to 1/2 (I think, 1/2; maybe they are 3/8 couplers but definitely larger than the standard 1/4). I found that the bottleneck was the 1/4 couplers and fittings. Going one size larger delivered much more air to the tool without the need for the larger hose.[/QUO
My reply too!
   / Air hose 1/2 vs 3/8 - ? #6
I use 3/8 inch at home and we do at work also. This size will handle drills and my high speed router/grinder. We do use 1 inch hoses for our aircraft jacks.
All of these hoses are plugged into pigs (air plenum) that are fed with 1 inch lines.
We have light weight 3/8 air hoses built up short, about 10 feet long. We call these whips and mostly use them with our drills doing sheetmetal repairs.
hugs, Brandi
   / Air hose 1/2 vs 3/8 - ? #7
We have all 3/8 rubber hose, that is probably 20 years old, it works well for any air tools we have used.
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
20711 (A50323)
20711 (A50323)
Sundowner Rancher Express 20FT Livestock Trailer (A55302)
Sundowner Rancher...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
