Air hose 1/2 vs 3/8 - ?
   / Air hose 1/2 vs 3/8 - ? #1
9973720wb19
Platinum Member
East Coast
Many
I have an IR 60gal 5hp compressor. most of my tools are 1/4 inlet and I've been using a 3/8 hose. what size hose do most of you guys use?
   / Air hose 1/2 vs 3/8 - ? #3
As Above , All I have anymore is 3/8" except for my large impact wrench which I have a 1/2" hose for . Unless you go on a super long run , ( over 100' ) , 3/8" carries enough air for just about anything .
Fred H.
   / Air hose 1/2 vs 3/8 - ? #4
I have 3/8 hose but have changed my couplers on all my tools to 1/2 (I think, 1/2; maybe they are 3/8 couplers but definitely larger than the standard 1/4). I found that the bottleneck was the 1/4 couplers and fittings. Going one size larger delivered much more air to the tool without the need for the larger hose.
   / Air hose 1/2 vs 3/8 - ? #5
I have 3/8 hose but have changed my couplers on all my tools to 1/2 (I think, 1/2; maybe they are 3/8 couplers but definitely larger than the standard 1/4). I found that the bottleneck was the 1/4 couplers and fittings. Going one size larger delivered much more air to the tool without the need for the larger hose.[/QUO
My reply too!
   / Air hose 1/2 vs 3/8 - ? #6
I use 3/8 inch at home and we do at work also. This size will handle drills and my high speed router/grinder. We do use 1 inch hoses for our aircraft jacks.
All of these hoses are plugged into pigs (air plenum) that are fed with 1 inch lines.
We have light weight 3/8 air hoses built up short, about 10 feet long. We call these whips and mostly use them with our drills doing sheetmetal repairs.
hugs, Brandi
   / Air hose 1/2 vs 3/8 - ? #7
We have all 3/8 rubber hose, that is probably 20 years old, it works well for any air tools we have used.
EZ-GO TXT48 Electric Golf Cart (A57149)
EZ-GO TXT48...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
SDLanch SDLGC100 Crew Electric Golf Cart (A57149)
SDLanch SDLGC100...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
