8N Ford Tractor
   / 8N Ford Tractor #1
phillip1948
1948 8N Ford
I am having trouble with the hydralic lift i can get it to raise up but it will not go back down. I need to know how to fix it
   / 8N Ford Tractor #3
There is no hydraulic down-pressure on the 3PH. It is gravity ONLY. And the 3PH arms dont weight much.
So have you tried this with an implement on the back? or have you tried standing on the arms for a little added weight?
And you may also want to try asking in the parts/repair section.
Good luck and let me know if a little weight helps.
   / 8N Ford Tractor #4
Hello & WELCOME to TBN!
I moved your thread to the Ford Vintage Tractors Forum. :)
   / 8N Ford Tractor #5
if some weight on them don't make them drop.. pull the inspection cover with the dipstick in it and make sur ethe control rod from the top cover to the pump is moving fully back and forward witht he touch control handle. try helping it and see if the arms drop / raise
post back
ps.. dirty gritty oil can stick the exhaust portion of the control valveing too.
soundguy
Comfort Chute H Series Hoof Trimming Trailer (A50774)
Comfort Chute H...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
EZ-GO RXV Electric Golf Cart (A50121)
EZ-GO RXV Electric...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
