Massey Ferguson Sickle Mower Parts
   / Massey Ferguson Sickle Mower Parts #1
scsims
Central, KY
Mahindra 5525
I posted this in another forum but I thought it might get some better responses from MF guys.
I just bought a MF 7' sickle mower with the belt drive and I'm having trouble finding guards for the thing. No one seems to have aftermarket guards for it. The MF brand guards are around $50 a piece.
Does anyone know where I can get reasonably priced guards for it?
Original Part # 2 pronged guard 470353M1
Original Part # single guard 470349M1
   / Massey Ferguson Sickle Mower Parts #2
Call 270-528-2133 8-5 m-f. Ken Sweet
Ken I believe I talked with you today..... I call the Farm Parts place that you gave me and they only had single guards.
Do you know of if you have any laying around I could buy from you??
   / Massey Ferguson Sickle Mower Parts #4
I don't have anything. All MF mowers that come thru here have single guards on them at around $8 each. Ken Sweet
Do you think the single would work on my mower?
I took some pictures to see if you can identify the model. The model # on the the plate is worn off. The serial # is 238051064 I don't know if that mean much or not.
So I can replace the double guards with the singles then?? If so let me know where I need to come to get them.
Thanks,
Scott
   / Massey Ferguson Sickle Mower Parts #11
Thanks,
Scott
Sure, That is what came on them new. Ken Sweet
Ken can you tell me what the bar in the picture is for???? I seemed to have lost it today.
   / Massey Ferguson Sickle Mower Parts #13
Kicks the hay away from the drive box so the tractor tire and mower has a place to run on the next pass. Ken Sweet
I don't believe I will need it. I'm just cutting pond banks and ditches. I guess I tore it off somewhere. I figure out where when the bush hog hits it.
Thanks Ken.
I found out some more info on my mower today. I was told that my particular mower was only made a couple of years with the double guards and different clips. I can covert to the single guards, but I'll have to replace all of them and install different clips as well. So I'd be in for about $250. I think I'll hold off, but at least I have an option.
   / Massey Ferguson Sickle Mower Parts #16
I have an old Ferguson Sickle mower and lost the bearing out of it. I can't seem to find any to fit. Does anyone know the size of the large bearing in the housing and how do I get them out of the shaft? Also have the outer bearing off the belt pully, how do I get this bearing out, it was a ball bearing but nothing there but the case that held the balls. Its a model 31 ferguson, we have two of them, one is marked and other is not. Can anyone help us take out these bearing so we can get them matched up? We figure the large one size is 2 3/4" ID x 3" OD x 1" wide
The others are 1 1/4" ID x 2 1/2" OD x 5/8" wide
Lower bearing on the shafts is about the size of a quarter roller bearing x 1' wide.
Also have a Ferguson 1950 TO20 tractor, trying to put new axle seals on it, don't have the tools to do what is says in the book, but bought some acue seals that goes on the sweat collar? Where and how do I put this on the sweat collar? Please help someone.
   / Massey Ferguson Sickle Mower Parts #17
I have a sickel mower just like yours. Do you know the size of the bearings in the housing? How do I get them off the shafts, and how do I get the one out from the pully bearing? Can you help?
   / Massey Ferguson Sickle Mower Parts #18
Did you ever find where to get, or the after market number for the single guards? I have a 41 and am looking for a few guards, but I can not seem to find them ANYWHERE online, or even a number to use to search for them. Anyone have any help here?
   / Massey Ferguson Sickle Mower Parts #19
Anyone have any info on what guards are used on this mower, and where to get them?
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A59231)
Year: 2017 Make...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2011 Ford Expedition 4x4 SUV (A59231)
2011 Ford...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
UNUSED RAYTREE RMLS18T-18 TON HYD LOG SPLITTER (A60432)
UNUSED RAYTREE...
