OP
HydrauLink
I have a cat 1 tractor (Kubota L-3010) but I need a LONGER top link.
Should I get an extended screw for a cat 1 link OR will the cat 2 link work AND be longer?
Thanks![]()
Both of these products are now in-stock so I guess it really boils down to what length you need and how much weight you need to lift. Your tractor likely uses a category I hitch but a cat II will work if you use a sleeve to compensate for the differential. Those are cheap. I've attached a copy of our latest flyer with measurements on it for you to look at. Look at see what fits your needs best.
If I had to hazard a guess, I'd go with the cat I and an extended screw.
