Polaris 400 HO 4x4 at home (pics)
   / Polaris 400 HO 4x4 at home (pics)
Yes it runs great. I test drove a used 500 and it may have had a little more power but for what I am doing this will be more than enough.
   / Polaris 400 HO 4x4 at home (pics) #12
The 500 only has 3 more HP, not worth the extra money. How is it for stopping?? As the new ones do not have engine braking standard, but it can be added.
   / Polaris 400 HO 4x4 at home (pics) #13
There are some things that make a Sportsman what a Sportsman is. McPherson struts up front. Industry leading floating rear suspension. Braided stainless steel brake lines. Disc brakes all around. On demand 4WD. Sportsman's have been around for a while. For the rough stuff all the people I hunt with recommend the Sportsman. It will get you in and get you out.
No problems with brakes. Primary brake of course is the hand control but the foot brake also works well. Rear brake lights do not activate by the pedal-only the hand control.??? Not sure why.
   / Polaris 400 HO 4x4 at home (pics) #15
Thanks alot. Sounds good. You doing the first service, or dealer??
Dealer says to do it at 10 hours and it would be around 100.00. I am thinking of letting them do it and check it all over while there to make sure everything is ok. I bought the 2 year extended warranty so I want to make sure things are right from the start so they cant say I overlooked something and not be covered by the warranty.
   / Polaris 400 HO 4x4 at home (pics) #17
I think WilliamBos is talking about engine braking. An issue on the earlier Sportsman's with belt drive. Engine braking wasn't there on the early models. My 2007 Sportsman has the EBS (electronic braking system). It works very well. I'm sure your 2011 model has something similar.
   / Polaris 400 HO 4x4 at home (pics) #18
Good idea. Just make sure they clean the oil screen in the oil tank. Most usually do anyway. You could ask them to make sure they do.
   / Polaris 400 HO 4x4 at home (pics) #19
They took the EBS off in 2011, made it an option on the value line, to help keep the price down. It can be added though. When I buy, I may have it added.
   / Polaris 400 HO 4x4 at home (pics) #20
That's good info. No way would I have an ATV with out engine braking. Going head first down a cliff with out engine braking is a good way to be swatted by an ATV. Sometimes brakes are bad. I hate to hear that Polaris has made this an option. The EBS started as a patch for the short coming of the belt drive for lack of engine braking. EBS works extremely well.
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
