Cultipacker needed?
   / Cultipacker needed?
With the amount of money I am going to have to spend on seed and the amount of time, effort and money I have invested getting it to this point I do not want to mess it up now. I think I will just spend a little extra and get the cultipacker then hope for rain.
   / Cultipacker needed? #12
I'm a food plot nut and bought a cultipacker (used) a couple years back. It's a 7 footer - paid $1200. Too much, but that's what they go for these days - too many deer nuts out there, making them a valuable commodity. You can always poor-boy it with a Rube Goldberg solution but if you can afford it, by all means buy one. You will get more germination from the tiny seeds like clover and chicory. Good luck.
   / Cultipacker needed? #13
High price....tell me about it. I just bought a really nice used 8ft Leinbach for $1k. :( At first, the price seemed WAAAAYY high, but after you research the subject, my only alternative for an 8ft packer was to spend $1,400 - $1,800 for a new one or older used one!!
I'm looking forward to some nice food plots this fall. :D
Although the cultipacker is not absolutely needed, it definitely has its place, and it helps with germination and a level seed bed.
   / Cultipacker needed? #14
Guess I did pretty good. I bought an 8 foot Brillion 3 point hitch model that was used but still had 90+ % of the paint on it for $1100. The 3 point works fantastic for me because my plots are spread out over my property which is mostly wooded. Just pick them up and go!
   / Cultipacker needed? #15
Look around your area--I'll bet there's a cultipacker out there with your name on it.
I found this 9-ft cultipacker a few years ago about 40 miles from my place at a feed and seed store that had a lot of old refurbished tractors and implements for sale --paid $600. I'm sure you have similar outfits in your area.
Great idea. I have been calling around and as of yet have three leads that I need to go check out.
Thanks.
   / Cultipacker needed? #17
I'm stunned every time I see a price on a cultipacker these days. It wasn't all so long ago they'd not even draw a bid at auctions. No one wanted them. Most were sold for the scrap cast iron. I hauled a few home for junk myself. I can remember about 20 years ago, buying THREE fairly decent ones for $4. They ended up getting scrapped. If we knew then what we know now........
   / Cultipacker needed? #18
I think the popularity of food plots is a large factor in driving up the cost of cultipackers and grain drill/drop seeders. The prices for this stuff on eBay are stratopheric compared to the good old days.
I've been looking for a 6-ft Brillion seeder for several years--no luck finding one in my price range ($1-1.5K).
   / Cultipacker needed? #19
For sure the food plotters.....Plow prices went ballistic too. Usta be able to find NICE 2-bottom Ford 101's and Massey 43/62/66's for $150-$200 by the truck load. Now they're 3 or 4 times that much for the good ones, and just about as much for worn out junk.
Feebay and Craigslist haven't done anything to hold down prices either....
   / Cultipacker needed? #20
They sure are getting tougher to find, but you never know when you might get lucky and find one reasonable. Last fall, I got a 4 ft Brillion at a garage sale for $40. It had a couple broken wheels, but I was able to fix it up with some I took off of my old 8-footer (that was a little too wide for food plots anyway) and I had no problem at all selling it for $300 this spring. A couple weeks ago, I found another 8-footer with rotted out bearings and a broken frame for $50. All the wheels are good on that one, and it will make a nice winter project, welding up the frame and making new wood bearings. It is easy to make new wood bearings, which I did for my old 8-footer (now about a 7 footer), in a little over an hours time. Old cultipackers are simple to work on and they do make a big difference in how well a foodplot with small seeds (clover, brassicas, etc) germinates when compared to just dragging a log or sometin like that. I also like them for medium-sized seed like rye and wheat and using one on broadcast seed gives me nearly as good of results on these crops as when I used a grain drill in the old days. I also use mine for the final soil prep pass prior to planting large seeds like corn and soybeans. For that, I hook the cultipacker behind a drag, prior to using a row-planter which gives me a "cultimulcher". The row planter is still the best way to go with those larger seeds, as with those, germination that results from just broadcasting and cultipacking is not nearly as good. I would rate the cultipacker as my second most important food-plotting tool, behind only my JD 246, 2-row corn planter. 2-row corn planters are another item that has hit the stratosphere in prices in the last few years thanks to the increasing popularity of food plotting, especially if they have functioning fertilizer attachments as does my 246.
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
1717 (A54756)
1717 (A54756)
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
7046 (A50322)
7046 (A50322)
