my version of a KK xb dump trailer
   / my version of a KK xb dump trailer
I finally figured out how to make a slide show and up loaded it to You Tube :). It is rather long so I appologise to those who have dial-up internet :(. Enjoy the build from beginning to end here
‪Kens Fab DT 2 16‬‏ - YouTube
Let me know what ya think!!!! :D
   / my version of a KK xb dump trailer #163
Ken,
You did a great job! ... right from the start to the slideshow. Congrats. :thumbsup:
   / my version of a KK xb dump trailer #164
Well,
Great job! Good to see from the beginning to end....
I may have read earlier that the Ram must be at 15degrees minimum, but had forgotten. The slides did the reminding!! :):)
Thanks all. It was a fun project and a usefull one I might add! :thumbsup:
   / my version of a KK xb dump trailer #167
Well,
How do you figure that? What happens if the ram is less than 15 degrees?
   / my version of a KK xb dump trailer #168
Nice trailer. It looks factory. :thumbsup:
Chad
I thought that was what I read on your blog! It makes it easier for the ram to make the initial lift with the more angle of degree you have.
Thank you all for the kind words!:thumbsup:
this is from your dump trailer build comment #18,
The minimum pressure pump I would get would be 1700 PSI, and I have a 2" cylinder that is 24" retracted and 36" extended. This provides just over 5300 pounds of push force. I ran the numbers once already for attaching the cylinder base near the front and pushing back. This was going to require me to have the base of the cylinder something like 14" below the deck, and When fully extended it would only dump the trailer to about 33 degrees. That was not acceptable. If I attach the cylinder to the furthest forward point on the dump bed and the base of it in front of the rear axle, I only need a 16.3 degree angle to provide the 1500 pounds of upward force. I would have to have the base of the cylinder at least 6.72 inches below the deck. I can live with that. This also will dump the bed to about 51 degrees.
I may have read elsewhere that 15* would be minimum angle to be able to dump it.
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
49205 (A55788)
49205 (A55788)
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
