Where can you buy Kubota tools?
   / Where can you buy Kubota tools?
The tool is designed to drive a metal sleeve/ring to a predetermined depth on the end of the crankshaft. The depth is built into the sleeve tool. I contacted K-Line Industries, the tool maker, and they referred me back to Kubota. I also checked OTC/SPX but they only list automotive tools. Since Bobcat uses Kubota engines, I checked their website but they don't show anything.
   / Where can you buy Kubota tools? #12
If you know what the depth is, a decent machine shop should be able to build the sleeve for you for less than $100.. it's not like you'll be using it every day, so if it does the job at least once you're ok.
Sean
Sean
Certainly worth looking into. I have the measurements. Thanks.
   / Where can you buy Kubota tools? #14
I checked with the local dealer and the tool number was superseded with a kit that cost $596. The dealer could probably do the whole job for less than that. It takes three hours labor to do the complete repair.
The kit comes with a dehydrated Kubota mechanic in the bag. Just add water and he does all the work for you.
   / Where can you buy Kubota tools? #15
You can check with your local dealer. Maybe you bring it down to them (not sure if that's possible) and pay them to install it for you. It could be your cheapest option.
   / Where can you buy Kubota tools? #16
Are looking for a sleeve or driver or both? Your 1st post said sleeve, that is why I wanted to see a picture of a $100.00+ sleeve.
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
Ford Tractor (A50120)
HarbinGer V3 Plus...
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
