Where can you buy Kubota tools?
   / Where can you buy Kubota tools?
The tool is designed to drive a metal sleeve/ring to a predetermined depth on the end of the crankshaft. The depth is built into the sleeve tool. I contacted K-Line Industries, the tool maker, and they referred me back to Kubota. I also checked OTC/SPX but they only list automotive tools. Since Bobcat uses Kubota engines, I checked their website but they don't show anything.
   / Where can you buy Kubota tools? #12
If you know what the depth is, a decent machine shop should be able to build the sleeve for you for less than $100.. it's not like you'll be using it every day, so if it does the job at least once you're ok.
Sean
Sean
Certainly worth looking into. I have the measurements. Thanks.
   / Where can you buy Kubota tools? #14
I checked with the local dealer and the tool number was superseded with a kit that cost $596. The dealer could probably do the whole job for less than that. It takes three hours labor to do the complete repair.
The kit comes with a dehydrated Kubota mechanic in the bag. Just add water and he does all the work for you.
   / Where can you buy Kubota tools? #15
You can check with your local dealer. Maybe you bring it down to them (not sure if that's possible) and pay them to install it for you. It could be your cheapest option.
   / Where can you buy Kubota tools? #16
Are looking for a sleeve or driver or both? Your 1st post said sleeve, that is why I wanted to see a picture of a $100.00+ sleeve.
2012 EAGER BEAVER 55GSL/3 RGN TRAILER (A53843)
2012 EAGER BEAVER...
2004 BMW Sedan (A51694)
2004 BMW Sedan...
2019 Genie GS-3232 32ft Scissor Lift (A53421)
2019 Genie GS-3232...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
12 in Small Excavator Bucket (A52377)
12 in Small...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
