can someone id this backhoe and answer a couple of questions?
   / can someone id this backhoe and answer a couple of questions? #1
jon1996
I am looking into trading for this older Backhoe, I know its a ford and the guy said it has sherman power digger on the rear boom, its in good shape and everything works, But I can not find one like it to figure out the model numbers, and I was wanting to know how much is it worth and how much it weighs
Jon
   / can someone id this backhoe and answer a couple of questions? #2
It looks like an old 801 or 841 with an added loader and backhoe.
If you can get the serial number, I think Soundguy can help you translate the numbers.
He may even be able to tell you where to locate the numbers stamped in the housing.
Mark
Well I thought the same, but it does not have a 3'point hitch and had never had one it is a backhoe but looks like a tractor I have it narrowed down to one of the 60's industrial backhoes a 3550 looks close I thought but it's not this one has 13x28 tires on it as to where the 3550 has 24" tires so I have no idea
   / can someone id this backhoe and answer a couple of questions? #4
You aren't even close in thinking it is a 3550. For starters, a 3550 has a 3 cylinder engine and wet brakes and is more than a decade newer than the tractor in the photo. The photo appears to be of an 801 series tractor.
ok then I am wrong heres what the guy told me over the phone
Its in the 60's
its a 4cyl gas engine
Has sherman Digger on rear backhoe arm
28" rear tires
has three headlights in front one larger one in the center
Thats all I know about it
Thanks,
jon
   / can someone id this backhoe and answer a couple of questions? #6
Its in the 60's
28" rear tires
Thanks,
jon
It looks just like my neighbors IH, post some more pictures. I think it's a 3414. His has no pto and no 3pt hitch, just a loader.... 2wd.
http://www.tractordata.com/industrial-tractors/000/0/6/60-international-harvester-3414.html
   / can someone id this backhoe and answer a couple of questions? #7
Some pictures:
Ford 801: Ford 800 Tractor/Backhoe for sale
Ford 4000 (Note the different backhoe boom design): http://www.tractorbynet.com/forums/ford-vintage-tractors/30136-ford-4000-tractor-loader-backhoe.html
Ford 3400 (note the different grill and backhoe boom): FORD TRACTOR / LOADER / BACKHOE | Belton | eBay Classifieds (Kijiji) | 12675116
Ford 800 (note the different backhoe boom and similar grill): Johnny King Auctioneers Gallery :: Farm/Const/Landscape Equipment :: Ford_800_series_Tractor_with_Loader_and_Backhoe
IH 3414: http://www.tractorbynet.com/forums/case-ih/142043-international-3414-restoration.html
Looks most like a Ford 801 to me.
Edit: As I recall, Sherman made quite a few things for Ford (including transmissions, loaders, and backhoes)
Aaron Z
The front loader on the 800 is nothing like this one, the rear backhoe looks similar, but this is a ford for sure even though the IH looks like it the most heres another pic, I have more if anyone wants them
   / can someone id this backhoe and answer a couple of questions? #9
That's an old 1800 series industrial, they were build off the 800 series
versions were -
1811: Select-O-Speed, no PTO or hydraulics
1821: Four-speed, no PTO or hydraulics
1841: Four-speed with PTO and hydraulics
1871: Select-O-Speed with PTO and hydraulics
1881: Select-O-Speed with multi-speed PTO and hydraulics
I think there was another one or two, but I haven't worked at a Ford dealer since the 90's, starting to forget some of it!
nice old tractor in it's day. I can't remember the loader # but parts for that hoe will be a real pain, long obsolete from Ford. Buy it to play with, not to really work hard much. JMHO
   / can someone id this backhoe and answer a couple of questions? #10
Here is an 861 (or is it an 801? The ad calls it an 861, but the picture calls it an 801) which has the same loader, but a different power steering mechanism:
Source: Used Tractors » Helena Farm Supply - Serving Montana for over 60 years
And: http://www.helenafarmsupply.com/web_images/ford801.jpg
Per: 1950 Ford 8N Serial # 306967 (scroll all of the way down), that is a Ford 703 loader
Per: 1970 FORD 703 Other Equipment - Loaders For Sale At TractorHouse.com
This loader can be installed on:
1801, 1811, 1821, 1841, 1871, 1881, 2N, 2000, 4000, 4030, 4031, 4040, 4110, 4120, 4130, 4131, 600, 601, 620, 630, 640, 650, 660, 700, 740, 800, 801, 811, 820, 821, 840, 841, 850, 851, 860, 861, 871, 881, 8N , 900, 901, 941, 950, 951, 960, 961, 971, 981, 9N, NAA, NAB 2000 3000
Here is an 801 with a 703 loader: Ford 801 Tractors | KROMMINGA MOTORS MONTICELLO, IA
Aaron Z
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
